Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: MDX and COM big update
  1. #21
    Nov 2008
    So far i have been able to get MDX to send codes to RR, but when i want RR to read my FB temp sensor and display the results in one of the skins it doesnt show any data. I tried to start very basic and just get a reading from the analog input but i cant get the voltage to display either. Any tips??
  2. #22
    Constant Bitrate stealinfool's Avatar
    Dec 2005
    Orlando
    Quote Originally Posted by 2k1Toaster View Post
    Values sent from MDX and displayed by RoadRunner:
    MDX Code:
    Nothing specific, it is built off of any configuration file.
    RoadRunner Code:
    Code:
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L03,260,10,150,30,255,255,255,18,"Arial Narrow:B","fusion_ai_0", ""
    L04,410,10,180,30,128,255,128,18,"Arial Narrow:B","fusion_ai_0_3", ""
    L03,260,10,150,30,255,255,255,18,"Arial Narrow:B","fusion_do_0", ""
    L03,260,10,150,30,255,255,255,18,"Arial Narrow:B","fusion_di_0", ""
    L05,260,40,150,30,255,255,255,18,"Arial Narrow:B","fusion_varbool_0", ""
    L06,410,40,180,30,128,255,128,18,"Arial Narrow:B","fusion_varnum_0", ""
    What it does:
    When a RoadRunner label is set to that above, it will poll MDX automatically. Like before, MDX only tries to interpret things that begin with "fusion".
    The next field is the type, which can be "ai", "do", "di", "varbool", "varnum" which give you back respectively: analogue input, digitial output, digital input, boolean variable, numeric variable.
    The next number is the index. 0 means the 1st one, 4 means the 5th one. The number is determined by the order in the configuration file, NOT the port number. 0th item is the top of the file, Nth item is at the end of the file.
    The optional fourh parameter is the decimal precision, only works on analogue inputs.
    These will automatically update as RoadRunner constantly polls.
    From what I understand, that should do it. Try the various "ai_xx" numbers until you come up with a value. I'm only regurgitating though, so if you can't make that work, hopefully someone else can help.
  3. #23
    Nov 2008
    yeah, i have tried that. I tried every number from 0 to 10, and even 00-10. i only have one analog input, so it should be easy to find.
  4. #24
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by faron View Post
    If you have the configuration file correctly setup with your Brain instance, analogue input instance, then count how many analogue instnaces are before it, (in your case it should be 0 above it so your index would be zero).
    In the COM area make sure you have it enabled and setup exactly as above.
    Make sure you are using the updater. If you dont update, I dont help.
    The code in RR would be "L03,260,10,150,30,255,255,255,18,"Arial Narrow:B","fusion_ai_0", """
    Make sure the DLL is registered. If you didnt use the installer recently, and had MDX installed before the COM update, then run the registration command file in the MDX directory.
    1.9in x 2.9in -- 47mm x 73mm
  5. #25
    Nov 2008
    I decided to try it on a fresh machine, so i istalled MDX w/Updater, Installed RR and started from scratch. As before the com test buttom works on MDX when i press it the play command is sent to RR. I am still unable to get RR to turn on digital outputs, or get RR to show any value from my analog input. I'm sure it is something simple I am missing, but I will send some one copies of the MDX config file and a copy of the RR skin file where I am calling these functions if someone thinks they could help. I am about to pull my hair out this has been driving me crazy for 3 days. Any help would be greatly appreciated.
  6. #26
    Aug 2006
    Central PA
    I used your example and it works great! If I wanted to use your example to use a trigger like a resistance from a steering wheel button how would I modify your example? I'm assuming starting with removing functionTargetID="Digital Output 0" .
  7. #27
    Nov 2008
    I am still trying to get this to work, I have copied and pasted exactly as above with no luck. I am using the updater and I ran the registration command.
    I sthere a possability some one could send me a sample configuration file that works for them. I am pretty sure that RR is sending the command, but MDX isnt rcognizing it. When I ren RR in debug mode i see that it sends fusion_vote_RoadRunnerCommand but the outputs never energize.
  8. #28
    Dec 2005
    Orlando
    Quote Originally Posted by scotty562 View Post
    Is that directed to me?
  9. #29
    Aug 2006
    Central PA
    It was directed to Nick, but I'll take suggestions from anyone who knows.
  10. #30
    Mar 2006
    Ok, scotty and faron, post your xml code from the COM section, and RR.
