Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 63
Thread: MDX and COM big update
  1. #31
    Nov 2008
    MDX Code
    <general>
    <!-- Begin Remote Control Configuration -->
    <remote status="disabled" user_name="default" port="4242"></remote>
    <!-- End Remote Control Configuration -->
    <com status="enabled">
    <commands>
    <command id="RoadRunnerCommand" minimum_delta_vote_time="100">
    <do function="trigger output" functionTargetID="Digital Output 0" vote_opinion="on" vote_priority="medium"></do>
    <do function="trigger output" functionTargetID="Digital Output 1" vote_opinion="on" vote_priority="medium"></do>
    </command>
    </commands>
    <executable_commands>
    <external_COM_id id="RoadRunner.SDK">
    <command internal_id="RoadRunnerCommand_PLAY" external_command="Execute">
    <parameter order="0" external_command_parameter="PLAY" />
    </command>
    </external_COM_id>
    </executable_commands>
    </com>
    </general>
    RR code
    B,75,372,254,48,"fusion_vote_RoadRunnerCommand",
    L,96,402,602,135,255,255,255,18,"Arial Narrow:B","fusion_ai_0",
  2. #32
    Mar 2006
    Colorado, but Canadian!
    Ok, can you also post the code from your "io" area please
    1.9in x 2.9in -- 47mm x 73mm
  3. #33
    Nov 2008
    <io>
    <!-- Begin Fusion Brain Instances -->
    <brain id="My Fusion Brain 0">brain id 0</brain>
    <!-- End Fusion Brain Instances -->
    <!-- Begin Timer Setup -->
    <timer id="input" interval="75"></timer>
    <timer id="output" interval="100"></timer>
    <timer id="gui" interval="50"></timer>
    <timer id="logic" interval="50"></timer>
    <!-- End Timer Setup -->
    <!-- Begin Digital Output Instances -->
    <iochannel id="Digital Output 0" port="0" brain="my fusion brain 0" type="digital_output">
    <defaults defaultstate="off"></defaults>
    </iochannel>
    <iochannel id="Digital Output 1" port="1" brain="my fusion brain 0" type="digital_output">
    </iochannel>
    <iochannel id="Digital Output 2" port="2" brain="my fusion brain 0" type="digital_output">
    </iochannel>
    <!-- End Digital Output Instances -->
    <!-- Begin Analogue Input Instances -->
    <iochannel id="Analogue Input 0" port="0" brain="my fusion brain 0" type="analogue_input">
    <options history="15" auto_average="true"></options>
    </iochannel>
    <!-- End Analogue Input Instances -->
    </io>
  4. #34
    Mar 2006
    If you make a button to turn it on, does it work? How are you testing that it works or doesnt work? Can you make a virtual brain (under debug options) for testing?
  5. #35
    Nov 2008
    i have a button in FCC to turn those outputs on, and they come on. I have a virtual brain setup right now testing it.
  6. #36
    Nov 2008
    i still cant get RR to control Fusion, I get fusion to control RR fine
  7. #37
    Nov 2008
    Any ideas?
  8. #38
    Mar 2006
    what version is your exe?
  9. #39
    Nov 2008
    3.1.0.772
  10. #40
    Mar 2006
    I will be getting to you and figure this out. This is just a really bad time right now.
    I had 4 finals today, 1 tomorrow, 1 wednesday, and some essays and projects to do for university.
    After Thursday/Friday, things will be calmed down a bit and I will be able to start working on this again.
    So just so you know I am not trying to ignore you, and later this week I can get back working on it.
