Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 63
Thread: MDX and COM big update
  1. #41
    Nov 2008
    Quote Originally Posted by 2k1Toaster View Post
    I will be getting to you and figure this out. This is just a really bad time right now.
    I had 4 finals today, 1 tomorrow, 1 wednesday, and some essays and projects to do for university.
    After Thursday/Friday, things will be calmed down a bit and I will be able to start working on this again.
    So just so you know I am not trying to ignore you, and later this week I can get back working on it.
    I totally understand, I've been there! Just whenever you get time I would really appreciate your help.
  2. #42
    JiC
    JiC is offline
    Sep 2008
    I think I'm in the same boat as faron.
    Here is my code:
    general section:
    Code:
      <general>
      <debug status="on">
       <virtual_brain id="my fusion brain 0"></virtual_brain>
      </debug>
      <!-- Begin Remote Control Configuration -->
        <remote status="disabled" user_name="default" port="4242"></remote>
      <!-- End Remote Control Configuration -->
      <com status="enabled">
        <commands>
          <command id="ResetUSB" minimum_delta_vote_time="100">
            <do function="trigger output" functionTargetID="digital output 0" vote_opinion="on" vote_priority="medium"></do>
            <do function="trigger output" functionTargetID="Digital Output 1" vote_opinion="on" vote_priority="medium"></do>
          </command>
        </commands>
        <executable_commands>
          <external_COM_id id="RoadRunner.SDK">
            <command internal_id="RoadRunnerCommand_PLAY" external_command="Execute">
              <parameter order="0" external_command_parameter="PLAY" />
            </command>
            <command internal_id="RoadRunnerCommand_NEXT" external_command="Execute">
              <parameter order="0" external_command_parameter="NEXT" />
            </command>
            <command internal_id="RoadRunnerCommand_PREV" external_command="Execute">
              <parameter order="0" external_command_parameter="PREV" />
            </command>
            <command internal_id="RoadRunnerCommand_VOL+" external_command="Execute">
              <parameter order="0" external_command_parameter="VOL+" />
            </command>
    	<command internal_id="RoadRunnerCommand_VOL-" external_command="Execute">
              <parameter order="0" external_command_parameter="VOL-" />
            </command>
          </external_COM_id>
        </executable_commands>
      </com>
      </general>
    My I/O Code:
    Code:
      <io>
      <!-- Begin Fusion Brain Instances -->
          <brain id="My Fusion Brain 0">brain id 0</brain>
      <!-- End Fusion Brain Instances -->
      <!-- Begin Timer Setup -->
          <timer id="input" interval="75"></timer>
          <timer id="output" interval="100"></timer>
          <timer id="gui" interval="50"></timer>
          <timer id="logic" interval="50"></timer>
      <!-- End Timer Setup -->
      <!-- Begin Digital Output Instances -->
          <iochannel id="Digital Output 0" port="0" brain="my fusion brain 0" type="digital_output">
            <defaults defaultstate="off"></defaults>
          </iochannel>
          <iochannel id="Digital Output 1" port="1" brain="my fusion brain 0" type="digital_output">
          </iochannel>
      <!-- End Digital Output Instances -->
      <!-- Begin Analogue Input Instances -->
          <iochannel id="Analogue Input 0" port="0" brain="my fusion brain 0" type="analogue_input">
            <options history="15" auto_average="false"></options>
          </iochannel>
      <!-- End Analogue Input Instances -->
      </io>
    And in RR's ExecTBLE.ini:
    Code:
    "ONSONGSTART","fusion_vote_ResetUSB"
    "ONSKINSTART","fusion_vote_ResetUSB"
    "ONSUSPEND","fusion_vote_ResetUSB"
    "ONRESUME","fusion_vote_ResetUSB"
    MDX is sending the commands to RR without any problems, however I can not get RR to turn that damn input on! exe version is 3.1.0.772
  3. #43
    Mar 2006
    Colorado, but Canadian!
    Ok. I used your code, and my exe and my RR, and it works. It turns both inputs on.
    Use the updater to get the new exe.
    As for the other files:
    Fusion Config file: http://www.fusioncontrolcentre.com/T...figuration.xml
    RoadRunner Skin file for BMV2: http://www.fusioncontrolcentre.com/T..._001/menu.skin
    Full BMV2 Skin if you dont have it (includes that skin file): http://www.fusioncontrolcentre.com/T...M_001/BMV2.rar
    If that doesnt work, there is something going on within RoadRunner.
    1.9in x 2.9in -- 47mm x 73mm
  4. #44
    Mar 2006
    And the new file version for MDX is 3.1.0.792
    Also if it doesnt work, run the "FusionCOM_Registration.cmd" file to register that dll. And dont move the dll's to RR's folder.
    Also make sure you have this in your RR skin file:
    Code:
    /, Fusion Control Centre
    X,FusionCOM
  5. #45
    Nov 2008
    thank you very much, that seems to work. I guess i was missing the:
    X,FusionCOM
    Also I ran the updater manually, plus it runs every time i start up the machine and the version of the exe remains 3.1.0.772. The updater says no updates available.
  6. #46
    Mar 2006
    Quote Originally Posted by faron View Post
    X,FusionCOM
    That's because I forgot to upload the xml file to the server!
    Fixed now.
    What about jic, does it work for you now?
    And again sorry for the delay, but I am all ears for a while now.
  7. #47
    JiC
    JiC is offline
    Sep 2008
    Don't worry about the delay I still think this is super timely and helpful support! I just finished some exams myself so I'm going to give this a try tonight. I was also missing the X,FusionCOM line so i have a feeling that will make the difference for me. I'm just having one other issue I'd like to figure out before I bring the new files down to the car. I made another thread.
  8. #48
    Mar 2006
    Quote Originally Posted by JiC View Post
    ok, well the X,FusionCOM is what tells RoadRunner to even look at external COM obejcts basically. So it is 100% required.
    Let me know if it works.
  9. #49
    JiC
    JiC is offline
    Sep 2008
    Awesome, it's working perfectly now. Well almost perfectly.
    on startup I call FCC (because it runs RR for me)
    using "ONSKINSTART","fusion_vote_ResetUSB" makes RR throw an error because RR loads faster then MDX.
    So I need to find a way for RR to delay sending that command.
    I have very limited knowledge of RR's commands right now. I know that there is a wait command -- "WAIT;2" -- would wait 2 seconds. But I don't know if I can stack commands in the ExecTBLE.ini.
    "ONSKINSTART","WAIT;2,fusion_vote_ResetUSB" ??
  10. #50
    Mar 2006
    Well I dont know RoadRunner skinning either. Sounds like a question for the RR subforum.
    But why are you getting RR to send the command? Why not have MDX send the reset command on start?
