Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 63
Thread: MDX and COM big update
  1. #51
    JiC
    JiC is offline
    Sep 2008
    Some searching yields the answer
    "ONSKINSTART","WAIT;2||fusion_vote_ResetUSB"
    You make an excellent case, I wasn't sure how to trigger events in MDX when coming back from hibernate though.
  2. #52
    Dec 2008
    I may be a bit off-topic, but does it support media buttons?
    I'm talking about "the button you usually see like "play" "stop" fwd" "rew" "fwd" "+ vol" "- vol"
  3. #53
    Nov 2008
    is there a way around the confirmation windows where i have to click OK everytime i run a fusion command from RR?
  4. #54
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by faron View Post
    Those shouldnt be there...
    Oh I think I might have reenabled them to check if it is working or not in this thread, but I forgot to take them out in the one I put out.
    I have a new MDX ready, I am just making the configurator up to speed.
    This will be a big update, and the whole USB class is rewritten. It will also now use Microsoft's drivers for better compatibility.
    So I am hoping today I can get that out. It will mean uninstalling your drivers and reinstalling the new ones for anything to work.
    Also if using a version 3 board, you will have to add "version" tags to your brain isntances. Once I get the configurator up, it can do it.
    I will make a new thread that is more detailed once it gets released.
    1.9in x 2.9in -- 47mm x 73mm
  5. #55
    Nov 2008
    Ok, thank you. I will be on the lookout for the new thread.
  6. #56
    Mar 2006
  7. #57
    Mar 2006
    Quote Originally Posted by miantiao View Post
    If you connect the buttons to the Fusion Brain to the buttons yes it is doable.
  8. #58
    Dec 2008
    Quote Originally Posted by 2k1Toaster View Post
    Hmm... my question is, how can i perform other functions other than the 0-9, A-Z , Num0-Num9 Ctrl Alt via the Send Key function?
    The Media Buttons like i mentioned for the previous cases? Or even sending Ctrl + N ?
    i'm using both iTunes and WMP for my player and i want to trigger them using my steering wheel. The easiest way is to use the "Media Function". I even use some HotKey software to wire up F9 (media vol up)... F8( media Vol Down) but that doesn't seem to work...
  9. #59
    Dec 2008
    Dearest 2001 Toaster, pls help me!~ thanks~!
  10. #60
    Mar 2006
    Possible only to the top most window, and I do not have it coded in for media buttons. Other regular keys can work anywhere and are coded in.
    Why dont you just change the key shortcuts to regular keys?
