Definitions that make it easier:
Module: The block, main image, picture describing what it does
Node: The little circles on sticks protruding out of the module
Link: The actual line between the 2 modules connected between an output node and an input node on seperate modules
Answer:
So to connect, right click a node to begin with, then left click another node to end it. You can only connect output nodes of modules to input nodes on other modules. Loop-backs are not permitted. Both of these will show an error if it happens and prevent the linking.
So right click output node of module A, then left click input node of module B.
LinkBack URL
About LinkBacks
) that could be simplified to just the right button (or just the left). What was frustrating, though, was after clicking and dragging with the right button, getting an error message (don't start from an input) , trying it in reverse (outs to ins) with the right mouse button, and getting NOTHING. I was wondering if the lines weren't being rendered (due to a non-refresh,
