The last post in feb said "here is a beginning."
How do I get to it? Have I missed a thread that discusses it?
GadgetBandit
It is already in MDX. Not in the configurator. Probably wont be for a while.
But it is fully functional as far as I remember in MDX as of the late Feb. update.
1.9in x 2.9in -- 47mm x 73mm
GadgetBandit
It ain't a car. But the brain monitors my greenhouse and drives the hydroponics. It's a pain to run logic at 100 and try to count seconds. "Time" is important for 24 hour cycles. Please.
GadgetBandit
Sorry I missed replying, thought I had. Things have been hectic.
But it is in the current release, pretty sure it came just after I posted that post with the pic.
Here is the code:
Code:/* <task id="Task Test" minimum_delta_vote_time="1000"> <when year="XXXX" month="XX" day="01" hour="XX" minute="00" second="00" /> </task> <task id="Task Test 2" minimum_delta_vote_time="1000"> <when year="XXXX" month="XX" day="Thursday" hour="XX" minute="XX" second="00" /> </task> */
XX means dont care.
And day can be a day of the week as a string or a number.
Also numbers can have "X" in the spot anywhere in the number. So you could make the minute "X0" for it to fire every 10 minute tick and so on.
I had to go be an adult for a while. Anyway . . . let's pretend I have between 1 and 2 brains. Yours works fine. I use Dreamweaver rather than Configurator. Please show me how to fire the output with the "when" condition every 10 minutes.
<all_statements>
<if fire_on="logic" minimum_delta_vote_time="100" id="one_minute_logic">
<do function="Trigger Output" functionTargetID="My Digital Output" vote_opinion="on" vote_priority="Medium"></do>
</if>
</all_statements>
Thanks,
GadgetBandit
Just like explained above... This will turn the output on at XX:00:00, XX:10:00, XX:20:00, XX:30:00, XX:40:00, and XX:50:00.
Now if you want to turn it off, then make a new one and change the time to something for however long you want it on for. Say 1 minute, so then change it to:Code:<all_tasks> <task id="Turn ON the Output" minimum_delta_vote_time="100"> <when year="XXXX" month="XX" day="XX" hour="XX" minute="X0" second="00"> <do function="trigger output" functionTargetID="theDigitalOutputID" vote_opinion="on" vote_priority="medium" /> </when> </task> </all_tasks>
Also update before you run the task code.Code:<all_tasks> <task id="Turn ON the Output" minimum_delta_vote_time="100"> <when year="XXXX" month="XX" day="XX" hour="XX" minute="X0" second="00"> <do function="trigger output" functionTargetID="theDigitalOutputID" vote_opinion="on" vote_priority="medium" /> </when> </task> <task id="Turn OFF the Output" minimum_delta_vote_time="100"> <when year="XXXX" month="XX" day="XX" hour="XX" minute="X1" second="00"> <do function="trigger output" functionTargetID="theDigitalOutputID" vote_opinion="off" vote_priority="medium" /> </when> </task> </all_tasks>
Are "tasks" a subgroup, just like "logic declarations" in the xml file?
GadgetBandit
"Why won't this work?" !!!!!
Last night and all the morning, I've asked this question a thousand times!! . . . I just noticed your example was for "hours" not "minutes".
IT WORKS!!! Thank you!!!
Can I replace the "do function" with an "if" statement?
Thank you,
GadgetBandit
