Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Time triggered events
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by GadgetBandit View Post
    "Why won't this work?" !!!!!
    Last night and all the morning, I've asked this question a thousand times!! . . . I just noticed your example was for "hours" not "minutes".
    Whoops, you are right. Sorry about that, I am sort of drugged up at the moment from being in the hospital.
    IT WORKS!!! Thank you!!!
    Can I replace the "do function" with an "if" statement?
    Thank you,
    GadgetBandit
    You cannot replace the do statement with an if statement. The "if" is satisfied by time only.
    But what you can do is make the do statement change a variable. Then in the logic statements section use an if statement with the variable as well... a variable.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mar 2006
    I fixed the code example to minutes as it should be.
  3. #23
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    Setting a variable is excellent.
    Glad your doing good.
    GadgetBandit
  4. #24
    Jan 2010
    Just looking for some help with the same basic functions. I'm trying to set a variable to true or false based on the clock. i.e. true for day and false for night.
    I can do the logic all night but coding is not my stronger point. How would I modify the above code posted above to set a variable as opposed to triggering an output?
  5. #25
    Jan 2010
    how do I use the time based code to set a boolean variable? I can't figure out how to set boolean variables, only numerical variables.
  6. #26
    Mar 2006
    just use "true" or "false" instead of a number
  7. #27
    Jan 2010
    I guess it really was that simple. I have it working perfectly now. I'm now looking for a 1 or a 0 when I check that variable in my other functions (and it works that way), would that be the proper syntax or am I going to check for a true or false specifically to do it properly?
  8. #28
    Mar 2006
    true and false get translated into 1 and 0 anyways. Just leave it with numerics if you have it thatway already.
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. Replies: 8
    Last Post: 06-02-2007, 09:49 AM
  3. who cares about the date and time? (POLL)
    By liquid_smoke in forum Road Runner
    Last Post: 08-10-2005, 09:34 AM
  4. Looks like the time has come to find another frontend
    By TucsonPred in forum Media Engine
    Last Post: 08-01-2005, 03:52 PM
