Code:
<?xml version="1.0" encoding="utf-8" ?>
<FusionControlCentreConfiguration version="3.0" author="your mother" date_created="Thursday, December 04, 2008 at 10:24:13 PM" last_modified="Friday, December 05, 2008 at 2:33:57 PM">
<require>
<!-- Begin Function Instances -->
<!-- End Function Instances -->
<!-- Begin Fusion Font Instances -->
<font name="Verdana" originalSize="25" font_config="content\fonts\Verdana.xml"></font>
<!-- End Fusion Font Instances -->
</require>
<speech enabled="false" global_politeness="true">
<!-- Begin System Speech Instances -->
<!-- End System Speech Instances -->
<!-- Begin System Speech Definition Instances -->
<system_definitions>
</system_definitions>
<!-- End System Speech Definition Instances -->
<!-- Begin Custom Speech Definition Instances -->
<custom_definitions>
</custom_definitions>
<!-- End Custom Speech Definition Instances -->
<!-- Begin Custom Query Instances -->
<custom_queries>
</custom_queries>
<!-- End Custom Query Instances -->
</speech>
<general>
<!-- Begin Debug Instances -->
<debug status="off">
<window type="variables"></window>
<window type="ifthen"></window>
<virtual_brain id="my fusion brain 0"></virtual_brain>
</debug>
<!-- End Debug Instances -->
<com status="enabled">
<executable_commands>
<external_COM_id id="RoadRunner.SDK">
<command internal_id="RoadRunnerCommand_PLAY" external_command="Execute">
<parameter order="0" external_command_parameter="PLAY" />
</command>
<command internal_id="RoadRunnerCommand_NEXT" external_command="Execute">
<parameter order="0" external_command_parameter="NEXT" />
</command>
<command internal_id="RoadRunnerCommand_PREV" external_command="Execute">
<parameter order="0" external_command_parameter="PREV" />
</command>
<command internal_id="RoadRunnerCommand_VOL+" external_command="Execute">
<parameter order="0" external_command_parameter="VOL+" />
</command>
<command internal_id="RoadRunnerCommand_VOL-" external_command="Execute">
<parameter order="0" external_command_parameter="VOL-" />
</command>
</external_COM_id>
</executable_commands>
</com>
<!-- Begin Remote Control Configuration -->
<remote status="disabled" user_name="default" port="4242"></remote>
<!-- End Remote Control Configuration -->
</general>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="800,600" show_at_size="800,600" menubar="sizeable" RunInSystemTray="True" MinimizeToSystemTray="True"></main_display>
<!-- End Global Graphic Settings -->
<!-- Begin Background Images -->
<background_image style="stretch" imagefilepath="content\images\background_images\background.jpg" page="0"></background_image>
<!-- End Background Images -->
<!-- Begin Static Images -->
<staticimage>
<image path="content\images\static_images\button_larger.png"></image>
<display size="355,70" location="37,119" page="0" z_order="0.9"></display>
</staticimage>
<staticimage>
<display size="355,70" location="412,119" page="0" z_order="0.9"></display>
</staticimage>
<staticimage>
<image path="content\images\static_images\logo.png"></image>
<display size="556,27" location="123,44" page="0" z_order="0.9"></display>
</staticimage>
<!-- End Static Images -->
<!-- Begin Variable Location Images -->
<!-- End Variable Location Images -->
<!-- Begin Graph Instances -->
<!-- End Graph Instances -->
<!-- Begin Display Buttons -->
<!-- End Display Buttons -->
<!-- Begin Multi Images -->
<!-- End Multi Images -->
<!-- Begin Text Labels -->
<text_label id="Text_Label_SWC1" text="SWC1: " auto_monitor="variable" auto_monitorTarget="variable_swc1">
<font font_id="verdana" font_size="25" colour="255,255,255,255"></font>
<display location="37,119" page="0"></display>
<config decimals="2" max_size="355,70"></config>
</text_label>
<text_label id="Text_Label_SWC2" text="SWC2: " auto_monitor="variable" auto_monitorTarget="variable_swc2">
<display location="412,119" page="0"></display>
</text_label>
<!-- End Text Labels -->
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="My Fusion Brain 0">brain id 0</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="input" interval="30"></timer>
<timer id="output" interval="30"></timer>
<timer id="gui" interval="30"></timer>
<timer id="logic" interval="30"></timer>
<!-- End Timer Setup -->
<!-- Begin Digital Output Instances -->
<!-- End Digital Output Instances -->
<!-- Begin Analogue Input Instances -->
<iochannel id="SWC1" port="0" brain="my fusion brain 0" type="analogue_input">
<options history="5" auto_average="true"></options>
</iochannel>
<iochannel id="SWC2" port="1" brain="my fusion brain 0" type="analogue_input">
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
</all_logging>
<!-- End Logging Setup -->
<!-- Begin Variable Declarations -->
<all_variables>
<variable name="variable_swc1">0</variable>
<variable name="variable_swc2">0</variable>
</all_variables>
<!-- End Variable Declarations -->
<!-- Begin Logic Declarations -->
<all_statements>
<if fire_on="logic" minimum_delta_vote_time="100" id="Logic for SWC1">
<variable do="set" name="Variable_SWC1">
<analogue id="SWC1" time="0"></analogue>
</variable>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="Logic for SWC2">
<variable do="set" name="Variable_SWC2">
<analogue id="SWC2" time="0"></analogue>
</variable>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="SW Vol UP Logic">
<boolean_operation type="between ii">
<parameter1>
<number>0.83</number>
</parameter1>
<parameter2>
</parameter2>
<parameter3>
<number>0.90</number>
</parameter3>
</boolean_operation>
<then>
<do function="external command" functionTargetID="RoadRunnerCommand_VOL+" vote_opinion="VOL+" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="SW Vol DOWN Logic">
<parameter1>
<number>2.0</number>
</parameter1>
<parameter2>
</parameter2>
<parameter3>
<number>2.09</number>
</parameter3>
<then>
<do function="external command" functionTargetID="RoadRunnerCommand_VOL-" vote_opinion="VOL-" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="500" id="SW Track Next Logic">
<parameter1>
<number>0.01</number>
</parameter1>
<parameter2>
</parameter2>
<parameter3>
<number>0.37</number>
</parameter3>
<then>
<do function="external command" functionTargetID="RoadRunnerCommand_NEXT" vote_opinion="NEXT" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="500" id="SW Track Prev Logic">
<parameter1>
<number>0.38</number>
</parameter1>
<parameter2>
</parameter2>
<parameter3>
<number>0.40</number>
</parameter3>
<then>
<do function="external command" functionTargetID="RoadRunnerCommand_PREV" vote_opinion="PREV" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="1000" id="SW MODE PLAY PAUSE #">
<parameter1>
</parameter1>
<parameter2>
</parameter2>
<parameter3>
<number>2.25</number>
</parameter3>
<then>
<do function="external command" functionTargetID="RoadRunnerCommand_Play" vote_opinion="PLAY" vote_priority="Medium"></do>
</then>
</if>
</all_statements>
<!-- End Logic Declarations -->
</logic>
</FusionControlCentreConfiguration>
