Results 21 to 30 of 33
Thread: Can't figure it out!!!
  1. #21
    Jan 2009
    SWEET!!!
  2. #22
    Jan 2009
    Do I just need to let the updater take care of it or should I do a clean install? If I need to do a clean install where should I get the correct software?
    Thanks for all your help!
  3. #23
    Jun 2004
    The updater didn't do anything for me (not surprising, this isn't an update, so no new file version) I uninstalled the current program, then downloaded and installed the exe from the website. Worked after that.
    1 small issue - the ninja kitty wizard set my brain version to 4 rather than 3, once i fixed that, i can control the board again.
  4. #24
    Jan 2009
  5. #25
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ace123 View Post
    This is not an update just for the software, so I have not changed the updater. The problem lies in the DirectX files. Microsoft in their infinite wisdom recently changed their web install of DirectX which the installer was using. It no longer installs everything, or core components. So unless you had other programs that installed everything before, it wouldnt work. Now the installer includes all the DirectX files.
    Quote Originally Posted by Iamthehor View Post
    It isn't and update, but there is a new file version. New version is: 5.0.0.49
    Also the wizard will not change the version. That must be done in the box next to where you name and select its ID in the wizard manually. It defaults to 4. If you changed it to 3, and saved and it was 4, then that is a bug. Which case happened?
    Yes that is the source for all official downloads. The size is incorrect on the page, the download is correct though ~284Mb for all of them.
    1.9in x 2.9in -- 47mm x 73mm
  6. #26
    Jun 2004
    Quote Originally Posted by 2k1Toaster View Post
    Manually changed 4 to 3 in notepad and all was well - didn't see how to change it during the wizard, but i sped through it just trying to test the function.
    Version has changed, not sure where i saw 4.0.0.0, but i thought i saw it on both old and new .exe installer files.......noticed it was much bigger when downloading vs what it said on the site too...
  7. #27
    Jan 2009
    UPDATE...I downloaded the new installer and it worked the first time out! You guys rock! I've played around a bit and am really impressesd! Thanks for all your help on this guys I'll post my projects as soon as I get more familiar with the configurator! THANKS
  8. #28
    Mar 2006
    Glad you got it working!
  9. #29
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    Did You Uninstall and Update through the Device Manager?
    I believe, I did an Uninstall, Update Driver (Specifically Locate Drivers) and Shutdown. Avoiding MDX from installing the driver?
    GadgeBandit
  10. #30
    Jan 2009
    So does the control center not work on Vista at all? I downloaded the stuff to play and see if this is something I want to use, but all the main sections on my start menu's folder pop-up with a "stopped working" error.
  1. Can't figure out the right PSU!!
    By The1Architect in forum Power Supplies
    Last Post: 04-20-2008, 10:57 PM
  2. Help me figure out what has my COM1 tied up?
    By judoGTI in forum General Hardware Discussion
    Last Post: 06-29-2007, 11:12 PM
  3. Can't figure out why amps run so hot HELP
    By vortex1521 in forum Car Audio
    Last Post: 07-22-2006, 10:40 AM
  4. Pioneer 4800 cant figure out aux input?
    By slaya786 in forum Car Audio
    Last Post: 06-05-2006, 02:05 AM
  5. cant figure out the keys
    By vicky_obee in forum PowerVoice
    Last Post: 06-18-2005, 10:01 PM
