Page 4 of 4 FirstFirst 1234
Results 31 to 33 of 33
Thread: Can't figure it out!!!
  1. #31
    Sep 2005
    Australia
    Quote Originally Posted by madmikexb View Post
    So does the control center not work on Vista at all? I downloaded the stuff to play and see if this is something I want to use, but all the main sections on my start menu's folder pop-up with a "stopped working" error.
    Try to right-click, then run as administator. This should work If its a UAC issue.
  2. #32
    Jan 2009
    Not sure if it works on vista. I am using a dedicated XP box for it and it worked great. I haven't retried the vista machine since the original 18 meg installed glitch. I know that the drivers can be an issue....do a clean install of mdx and when you plug in the brain, go to device manager and make sure it is using the appropriate driver. Hope this helps.
  3. #33
    Mar 2006
    Colorado, but Canadian!
    Yes it works on Vista x86 and XP x86. No 64bit OS. My developement machine is Vista Ultimate x86.
    1.9in x 2.9in -- 47mm x 73mm
  1. Can't figure out the right PSU!!
    By The1Architect in forum Power Supplies
    Last Post: 04-20-2008, 10:57 PM
  2. Help me figure out what has my COM1 tied up?
    By judoGTI in forum General Hardware Discussion
    Last Post: 06-29-2007, 11:12 PM
  3. Can't figure out why amps run so hot HELP
    By vortex1521 in forum Car Audio
    Last Post: 07-22-2006, 10:40 AM
  4. Pioneer 4800 cant figure out aux input?
    By slaya786 in forum Car Audio
    Last Post: 06-05-2006, 02:05 AM
  5. cant figure out the keys
    By vicky_obee in forum PowerVoice
    Last Post: 06-18-2005, 10:01 PM
