Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Can't figure it out!!!
    Jan 2009
    Angry Can't figure it out!!!
    I have tried three different machines (2 vista, 1 XP) and have the same results. Every time I install the MDX software everything looks good until the end. I get "installation error" , yet the software still loads and the config editor works and can see the brain. To counter this, the control center WILL NOT work. Everytime I try to start it it throws a window error and closes. After reading other posts I completly uninstalled MDX and the drivers, made sure the machines had Net 3.5 and Directx 9.0c....restarted and then reinstalled. Still same issue across all three machines. I also installed the drivers manually. I feel I have overlooked somthing, any help on this is GREATLY appreciated!
    Side Question - after doing the Ninja Kitty how does I export this to the Brain? (obviously I'm new to the Fusion Brain)
    notes - three machines all 32 bit set as administrator, vista buisness, vista ultimate, XP Pro SP3
    - V4 Fusion Brain, MDX installer and drivers all from main FB website
    - I like Porsche
    Fusion Brain Creator
    Mar 2005
    Can you upload a screenshot of this error?
    Jan 2009
    screen shots
    here are the screen shots of the errors and drivers
    Name:  mdx drivers.jpg
    Name:  mdx error.jpg
    Name:  mdx install error.jpg
    let me know what you think. THANKS!!!
    Jun 2004
    I'm getting the same error on installation.
    It is at the final part of installation, looks like it's done, then just pops up a box with: (Header)ERROR (Body)install failed. The restart prompt then comes up and the updater does its thing (and reports that MDX has been updated). After restart, the configurator works, but MDX program doesnt - get an hourglass, but the process is never loaded.
    I had this working with the previous version of the software, and did a re-format for other reasons before installing the 12/22/2008 update.
    The Driver looks correct. .net 3.5 & DX9 installed OK
    WinXP SP2, updated 11/11
    Jun 2004
    Quote Originally Posted by ace123 View Post
    Save the configuration file as fusionconfiguration.xml in the MDX folder
    At least i can fix one problem.
    Jun 2004
    Screenshot
    Note - i just ran the installer a 2nd time over the already installed program - same error occurred the 2x i tried that.
    Jan 2009
    I save everything to the desktop for testing....the xml is labeld correct and in the right location....still same error
    I hate researching this problem because all i ever read about are peoples issues with code and such....I can't even see the control panle let alone screw up the code. It's OKAY...my day can't get any worse....ohhh just kidding it will be 0 deg F tonight!
    Mar 2005
    Nick Vergunst: well i dont know either. apparently my project has been corrupted
    Nick Vergunst: it runs fine on my dev machine
    Nick Vergunst: but the virtual machine it does the same thing now
    Nick Vergunst: I cannot fix it. I have been trying for the past 1.5hrs
    Nick Vergunst: I will have to try later
    we know about it, and are working on it.
    be patient.
    Jun 2004
    Sounds like you're saving the XML in the right spot - mine's doing the same thing. It worked before the update, i thought you might need to know where to save it.
    Greenman - Thanks for the work. I'm not in a hurry yet. But if it's not fixed by the 4th of July......
    This(and possibly a 2nd brain) will be controlling 200-250 fireworks so that i don't spend 2 hours with a lighter.
    Jun 2008
    Georgia, USA
    Quote Originally Posted by Iamthehor View Post
    ...This(and possibly a 2nd brain) will be controlling 200-250 fireworks so that i don't spend 2 hours with a lighter.
    I've wanted to try the same thing for a long time but have no idea how to light the fuses. What do you plan on using to ignite the fuses?
    Thanks,
    Dan
  1. Can't figure out the right PSU!!
    By The1Architect in forum Power Supplies
    Last Post: 04-20-2008, 10:57 PM
  2. Help me figure out what has my COM1 tied up?
    By judoGTI in forum General Hardware Discussion
    Last Post: 06-29-2007, 11:12 PM
  3. Can't figure out why amps run so hot HELP
    By vortex1521 in forum Car Audio
    Last Post: 07-22-2006, 10:40 AM
  4. Pioneer 4800 cant figure out aux input?
    By slaya786 in forum Car Audio
    Last Post: 06-05-2006, 02:05 AM
  5. cant figure out the keys
    By vicky_obee in forum PowerVoice
    Last Post: 06-18-2005, 10:01 PM
