Results 1 to 4 of 4
Thread: Control OEM radio from my head unit
    Oct 2008
    Hi
    I have same questions about Fusion brain.
    I want to control my oem radio with carpc.(ON,OFF,CD,......)
    This is oem radio plate.
    I want to control this push buttons with fusion brain.
    I m solder wire for each button.
    For do that if i must buy fusion brain and relay for each button?
    Sorry for my english.
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by boy36 View Post
    To do that, you need 1 fusion brain (can handle 16 relays) and then 1 relay for each button
    Jun 2004
    May not need relays - they're probably all 12V low current. Hard to determine that for sure though.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'm using optoisolators for controlling the push buttons for my HVAC unit. This is essentially the same problem as you're having. I just hooked up a 1kOhm resistor to pin 1 of my optoisolator (LAA110 - http://www.clare.com/home/pdfs.nsf/www/LAA110_R09.pdf/$file/LAA110_R09.pdf). It seems to work really well, when the digital output on the fusion brain goes high, the optoisolator (or a solid state relay) connects the terminals, emulating a push button
  1. head unit or no head unit... that is the question
    By FusionFanatic in forum General Hardware Discussion
    Last Post: 08-27-2007, 12:21 AM
  2. Replies: 1
    Last Post: 06-04-2007, 09:47 PM
  3. Radio with no head unit?
    By spoonraker in forum General MP3Car Discussion
    Last Post: 11-07-2006, 03:12 PM
  4. choosing a head unit
    By demonr in forum Car Audio
    Last Post: 09-17-2006, 01:56 AM
  5. New Sony head unit - botched wiring...
    By SamDude in forum Car Audio
    Last Post: 09-09-2004, 05:21 PM
