Results 1 to 6 of 6
Thread: Hiding Mouse Cursor in MDX
    Aug 2008
    Just wondering if it is possible (via an option / command line switch) to hide the mouse cursor when running MDX? I have a touchscreen so can control all my buttons with it; the mouse cursor is actually redundant.
    Mar 2006
    Colorado, but Canadian!
    No there isnt a way to hide the cursor. Are you using it in a frontend, or by itself?
    I can add it as an option pretty quickly. I'll try to incorporate it into the next release.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2008
    That would be awesome
    Using it in a frontend, hence would like to disable the mouse cursor. Perhaps a setting in the xml file or a command line switch? I'm not sure how my frontend (Centrafuse) handles passing on parameters to an embedded app though.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Ride Runner hides it still when you embed MDX into a skin
    Mar 2006
    Quote Originally Posted by QuickSSilver View Post
    Quote Originally Posted by bratnetwork View Post
    That's what I thought...
    I would have figured CF did the same.
    Mar 2006
    Ok, it is done.
    In the main graphics part of the configuration file add: HideCursor="True" (or "False" which is the default so it isn't needed).
    So my main graphics section starts like this:
    Code:
      <graphics>
      <!-- Begin Global Graphic Settings -->
          <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True" HideCursor="True"></main_display>
      <!-- End Global Graphic Settings -->
    This has not been released yet but next release should include it. Any exe with a version number of 5.0.0.130 or higher will include this feature.
  1. Real solution to G4 GPS being detected by Windows as crazy serial mouse?
    By johnk in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 03-18-2010, 07:11 PM
  2. How to use a configuration file created by the Configurator with MDX
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 09-08-2008, 05:36 PM
  3. Hiding the mouse
    By Speg in forum Media Engine
    Last Post: 06-22-2005, 02:58 AM
  4. PS2 3 Button(Rotary Wheel) Mouse Properties?
    By nFiniteTuning in forum Input Devices
    Last Post: 03-12-2005, 10:43 PM
  5. hiding the mouse when its not needed
    By Alives in forum General MP3Car Discussion
    Last Post: 07-07-2002, 12:42 PM
