Results 1 to 6 of 6
Thread: Display Button
    Aug 2008
    Decatur Illinois
    Display Button
    I have a Dell Laptop running Vista. When I try to create a new Display Button, the bottom portion of the panel is cut off (the panel is larger than my screen). Since there is no scroll function, I can't scroll down. I have tried to change resolution, but that does not help. How can I make the Display Button panel smaller so I can create buttons?
    Thanks,
    Fred Worrell
    Jun 2004
    my 14.4" screen has the same problem, you can slide the window up as much as possible & hide the taskbar, about it. I have to hope & pray I'm hitting OK when making changes to button config.....
    Aug 2008
    Decatur Illinois
    Thanks, That is what I might need to do. I was hoping there was a fix or that they could put a scroll bar or something.....
    Mar 2006
    Colorado, but Canadian!
    I have changed it to a tabbed window for it, it should be in the next update
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2008
    Decatur Illinois
    You're the best! I appreciate it.
    Aug 2008
    Decatur Illinois
    Most excellent. The tabbed windows fixed it completely! Thanks!
  1. Replies: 4
    Last Post: 02-24-2009, 05:19 AM
  2. Button request: Minimize
    By DaveB in forum Mobile Impact
    Last Post: 01-04-2007, 09:35 PM
  3. Determining button highlight order
    By parksgm in forum StreetDeck
    Last Post: 12-19-2006, 11:38 AM
  4. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 03:52 PM
