ohh well then i got my answer... ^^
hope bug will be fixed soon
Printable View
Its because the decimal point vs. comma for separating a number is different. I will have to fix it but easiest is to change regional settings to US/Canada or something.
well i can live with it for now. but i really hope there will be an update to fix the problem sometime... :)
Try this exe and let me know if it works: http://www.fusioncontrolcentre.com/T...2009_06_13.zip
doesn't work.. makes some kind fault...
"unhandled exception....."
"length cannot be less than zero. Parameter name: Length"
details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at System.String.Substring(Int32 startIndex, Int32 length)
at Fusion_Control_Centre_UberMDX.MainMDX.UpdateDaGUI( )
at Fusion_Control_Centre_UberMDX.MainMDX.UPDATE_GUI()
at Fusion_Control_Centre_UberMDX.MainMDX.GUI_Timer_Ti ck(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr oc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///e:/WIN/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Fusion Control Centre UberMDX
Assembly Version: 5.0.0.143
Win32 Version: 5.0.0.143
CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/Fusion%20Control%20Centre%20UberMDX.exe
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.DirectX
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
Microsoft.DirectX.Direct3D
Win32 Version: 9.05.132.0000
CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
Microsoft.DirectX.Direct3DX
Assembly Version: 1.0.2911.0
Win32 Version: 9.12.589.0000
CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2911.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll
System.Xml
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Speech
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Speech/3.0.0.0__31bf3856ad364e35/System.Speech.dll
FusionCOM
Assembly Version: 1.0.0.472
Win32 Version: 1.0.0.472
CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionCOM.DLL
FusionTypes
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionTypes.DLL
System.Configuration
CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
FusionBrain_WinUSB
CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionBrain_WinUSB.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
there is no fault now, but the temperature doesn't give right value.. volt seems right (0,8volt) but the temperature is wrong (1,5 and 1,6)
