Results 11 to 20 of 29
Thread: help with fusion brain
  1. #11
    Aug 2007
    ohh well then i got my answer... ^^
    hope bug will be fixed soon
  2. #12
    Jun 2008
    Georgia, USA
    Quote Originally Posted by greenman100 View Post
    He's in the hospital. He'll reply as soon as he can.
    Nothing serious I hope...send him a Get Well from everyone on the forums.
    Thanks,
    Dan
  3. #13
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Dan2008 View Post
    it's not life-threatening at all from what I understand. he should be back soon.
  4. #14
    Mar 2006
    Colorado, but Canadian!
    Its because the decimal point vs. comma for separating a number is different. I will have to fix it but easiest is to change regional settings to US/Canada or something.
    1.9in x 2.9in -- 47mm x 73mm
  5. #15
    Aug 2007
    well i can live with it for now. but i really hope there will be an update to fix the problem sometime...
  6. #16
    Mar 2006
    Quote Originally Posted by menthos View Post
    Try this exe and let me know if it works: http://www.fusioncontrolcentre.com/T...2009_06_13.zip
  7. #17
    Aug 2007
    doesn't work.. makes some kind fault...
    "unhandled exception....."
    "length cannot be less than zero. Parameter name: Length"
    details:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Length cannot be less than zero.
    Parameter name: length
    at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
    at System.String.Substring(Int32 startIndex, Int32 length)
    at Fusion_Control_Centre_UberMDX.MainMDX.UpdateDaGUI( )
    at Fusion_Control_Centre_UberMDX.MainMDX.UPDATE_GUI()
    at Fusion_Control_Centre_UberMDX.MainMDX.GUI_Timer_Ti ck(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///e:/WIN/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Fusion Control Centre UberMDX
    Assembly Version: 5.0.0.143
    Win32 Version: 5.0.0.143
    CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/Fusion%20Control%20Centre%20UberMDX.exe
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Microsoft.DirectX
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
    Microsoft.DirectX.Direct3D
    Win32 Version: 9.05.132.0000
    CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
    Microsoft.DirectX.Direct3DX
    Assembly Version: 1.0.2911.0
    Win32 Version: 9.12.589.0000
    CodeBase: file:///E:/WIN/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2911.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll
    System.Xml
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Speech
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Speech/3.0.0.0__31bf3856ad364e35/System.Speech.dll
    FusionCOM
    Assembly Version: 1.0.0.472
    Win32 Version: 1.0.0.472
    CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionCOM.DLL
    FusionTypes
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionTypes.DLL
    System.Configuration
    CodeBase: file:///E:/WIN/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    FusionBrain_WinUSB
    CodeBase: file:///E:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionBrain_WinUSB.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  8. #18
    Mar 2006
  9. #19
    Aug 2007
    there is no fault now, but the temperature doesn't give right value.. volt seems right (0,8volt) but the temperature is wrong (1,5 and 1,6)
  10. #20
    Mar 2006
    Did you change anything in the configuration file when you were trying to get it sorted out before?
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 17
    Last Post: 01-16-2009, 09:48 AM
  3. Replies: 3
    Last Post: 09-23-2008, 09:00 PM
  4. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 08:42 AM
  5. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 02:57 AM
