You need to leave those files alone. They need to use decimal points.
After you put those files back to the way they were, what values are showing up? Long values, wrong values, both???
ohh actually the values are from -1,5 to -1,6.. forgot the minus..
i changed the temp function..
instead of subtract 4, i subtract 0,4 and instead of divide by 1953 i divide by 19,53
but if i change value back, i just get the same values
1.9in x 2.9in -- 47mm x 73mm
the original value where:
subtract 4
multiply by 1000
divide by 1953
so i added the decimal points so i got:
subtract 0,4
multiply by 1000
divide by 19,53
i tried changing it back and forth but i get same values either way....
i tried to changed the value more to see if something did happen som i changed them to:
subtract 1
multiply by 1000
divide by 70
which gave me values of -1,7 to -1,85
if i use . instead of , the values change it self to 4 and 1953... somehow it seems like it can't show that decimal point...
i tried to run it anyway but got the same values as before, -1.5 to -1.6
i use the fusion brain configurator to change the values... when i press ok to the new value, it changes back to 4 and 1953 istead of 0.4 and 19.53...
tried changing them in notepad, and now it seems to be the right values... i get values of 25,3 and 24... actually i don't know the real temperature here but it looks like a temperature value noW![]()
The reason the configurator wont work is because they are very separate programs. I only just tried to fix the regional settings for MDX, I havent even released it as an update yet even. So obviously the configurator requires the decimal point regional settings like always.
Now that this is working, I can fix both and get an update out.
ok.. im just glad it is working![]()
