Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: help with fusion brain
    Aug 2007
    i have just recieved my fusion brain v4 +2temp sensors and accelerometer yesterday, and tried to use the configurator to make a simple test program to test my sensors...
    but it turned out to be not so easy as i thought...
    i have been trying to use the Ninja tool to create a config file for MDX, but when i run it, i get some really strange values:
    as you see i get some strange values both for temp sensors and accelerometer..
    so i tried to use a virtual brain instead, but then i got this fail:
    when i click continue, it reads the sensors value fine and i can see the value om the accelerometer changing when i move it...
    what am i doing wrong?
    Aug 2007
    bump?
    anyone can tell me why i get theese values??
    Aug 2007
    after studying the temp function i found 2 mistakes....
    my temp function goes like this:
    input_temp
    subtract 4
    multiply by 1000
    divide by 1953
    but after i changed the two values in bold to 0,4 and 19,53 the temperature started to make a bit more sense...
    now i actually can read the temperature, but there is still something wrong cause i get some like 15 digits:
    i tried to divide the final value by 1000000 in the temp function, but without luck...
    Fusion Brain Creator
    Mar 2005
    Is your computer set up in the US or international?
    Aug 2007
    it's a US install but all settings (keyboard and regional) are set to danish..
    Mar 2005
    Quote Originally Posted by menthos View Post
    That's why. PM 2k1Toaster for more info.
    Aug 2007
    ok, will try that.... thanks for help
    Aug 2007
    still no answer from 2k1Toaster
    Mar 2005
    He's in the hospital. He'll reply as soon as he can.
    Mar 2005
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  3. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  4. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  5. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
