Results 1 to 5 of 5
Thread: Change the state of a button
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    How would I change the state of a display button with an "if" statement?
    Thank you,
    GadgetBandit
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by GadgetBandit View Post
    Thank you,
    GadgetBandit
    Buttons are meant to change the state of things, not be changed externally.
    You can change variable images, or multi-images (made just for this capability really).
    What are you trying to do?
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2008
    I'm cycling a value with "when" tasks and want a manual off/on button that "appears" to change state when "when" turns on/off the value.
    A transparent button over a multi image!
    "when" and the button set variables
    The output is handled with "if"
    GadgetBandit
    Oct 2008
    Today I discovered that a button instance for triggering an output, changes state when you have a "when" statement also triggering the same output. After "when" triggers, the button becomes an "off" button until the next "when" cycle. Pretty cool. Exactly what I wanted.
    Thanks,
    GadgetBandit
    Mar 2006
    Thanks,
    GadgetBandit
    For that to work, you have to make sure your button is "attached" to the digital output.
    If you change it to "detached" that won't happen.
  1. Replies: 4
    Last Post: 06-28-2009, 08:49 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  4. M7NCG 400 7.2 Won't Allow Me To Change Power Button Behavior
    By msjonker in forum General Hardware Discussion
    Last Post: 09-16-2006, 06:59 PM
  5. Is there a way to change skins with a button?
    By wysocki in forum FrodoPlayer
    Last Post: 12-23-2004, 09:11 PM
