Results 1 to 10 of 12
Thread: install failed?
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    install failed?
    I brought my greenhouse computer in and re-installed your software and switched to the new brain. arg!! this is the result.
    If I click Ninja Kitty:
    Any directions?
    Thanks,
    GadgetBandit
    Jan 2008
    Dartmouth, MA
    Have you tried to do a full uninstall and then a normal install?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Oct 2008
    Did a full un-install. Loaded MDX Only, it worked. Did a full install. My file worked, except the "when" tasks we're hitting. Not knowing if the installation has the most current updates, I told it to update. arg!! Updater started a "flashy" thing, said it was done, and now I'm back to the prior errors. Tomorrow night I try again.
    GadgetBandit
    Mar 2006
    Colorado, but Canadian!
    in your configurator directory, delete the GTR template.
    Run MDX in debug mode so I can see what the error is.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2008
    thank you. I have to go be an adult for a couple days and will post the error on Saturday.
    GadgetBandit.
    Oct 2008
    I started from scratch, but I unplugged the internet before installing, so updater couldn't do its thing. Intalls fine, seems to works fine, except for my "when" tasks. So, I plug in the internet and updater runs. By all the flashing of file names, a number of files are uploaded. Then MDX is broken.
    Below is the text listed in the "Details" dropdown:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Fusion_Control_Centre_UberMDX.MainMDX.UpdateDaGUI( )
    at Fusion_Control_Centre_UberMDX.MainMDX.OnPaint(Pain tEventArgs e)
    at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventAr gs e, Int16 layer, Boolean disposeEventArgs)
    at System.Windows.Forms.Control.WmPaint(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Messa ge& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message & m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    Fusion Control Centre UberMDX
    Assembly Version: 5.0.0.178
    Win32 Version: 5.0.0.178
    CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/Fusion%20Control%20Centre%20UberMDX.exe
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Microsoft.DirectX
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
    Microsoft.DirectX.Direct3D
    Win32 Version: 9.05.132.0000
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
    Microsoft.DirectX.Direct3DX
    Assembly Version: 1.0.2911.0
    Win32 Version: 9.12.589.0000
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2911.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Speech
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Speech/3.0.0.0__31bf3856ad364e35/System.Speech.dll
    FusionCOM
    Assembly Version: 1.0.0.472
    Win32 Version: 1.0.0.472
    CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionCOM.DLL
    FusionTypes
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionTypes.DLL
    System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    FusionBrain_WinUSB
    CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionBrain_WinUSB.DLL
    Thanks,
    GadgetBandit
    Mar 2006
    Did you run it in debug mode?...
    Mar 2006
    Ok, you are using it in basic mode. That's why it is failing. Make sure you have DirectX installed.
    Run the updater now and the new exe fixes a bug in basic mode when you have an incomplete or corrupt DirectX install.
    Also make sure you reboot. Yes this is important.
    Oct 2008
    Booted, it updated, Configurator is fine. Everything "appears" fine but no "when" task. No error messages with debug mode. My files work except for "when", just ignores them. The other machine has no issue with the files.
    What is Basic Mode and does my ignorance of it, indcate a greater problem?
    Even though your installation does DirectX 9.0, are suggesting re-installing just DirextX?
    Lost,
    GadgetBandit
    Mar 2006
    Nothing in the code has changed regarding when
    If it has been a long time, you might have them on the wrong timer.
    Basic mode is when it cannot make a DirectX layer. Meaning install is wrong, system is old/incompatible, or just generally wrong. So it draws with GDI+ which is slow and a system hog instead. That's why you got that big red X in your error window.
    YOu can force basic mode by putting the command line switch of "basicgui". If you are not forcing it, then there is something wrong with the installation or your system.
    I would uninstall everything. Download a NEW installer. Then install that. Then restart your system.
  1. Bluetooth install error 183
    By prodigalsun in forum Bluetooth Hardware
    Last Post: 09-13-2011, 08:17 AM
  2. MicroXP install on VIA M10000II
    By Lucifer in forum WinNT Based
    Last Post: 07-08-2008, 06:45 AM
  3. CF card windows install
    By brendan in forum General Hardware Discussion
    Last Post: 07-03-2008, 04:07 PM
  4. Jagputer Install and story log
    By JagPuter in forum Show off your project
    Last Post: 08-02-2006, 09:48 PM
  5. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
