Results 1 to 2 of 2
Thread: Can't set Default State for Digital Outpust to "On"
    Newbie protodelorean's Avatar
    Jun 2007
    I'm working with a V3 FB and jsut downloaded all software yesterday (so I'm sure it's current)
    When I try to set the "Default State" of digital output 0 to "On", the setting won't stick. I click the green check to save and then if I immediately reopen the Digital Output, it's set back to "Off". I was able to edit it in Notepad and make the change work. Funny thing was Configurator then let me change the Default back to "Off" successfully, but then still won't let me go back to "On" from within Configurator. What's up?
    Thanks, Steve
    Mar 2006
    Colorado, but Canadian!
    It is a bug, and will be fixed.
    Like you say, editing the file manually should work in the interim. Sorry for any problems.
    1.9in x 2.9in -- 47mm x 73mm
  1. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  2. NMEA extraction AppleScript need help
    By zapwizard in forum MacCar
    Last Post: 05-05-2006, 02:10 AM
  3. Google Earth for OSX
    Last Post: 05-01-2006, 12:52 AM
  4. where to set Mobile Emulator default directory
    By ITL in forum Mobile Impact
    Last Post: 10-29-2005, 10:44 AM
  5. Anyway to set the default in CF to 3d view for MM?
    By bry21317 in forum Centrafuse
    Last Post: 02-25-2005, 10:55 AM
