My specific request would be to be able to chose a different date format for the output of the data. Right now it's Sunday, April 18, 2010 for example. I'd like to be able to export it as something Excel recognizes as a date format. Ex. 4/18/2010.
Another nice option to have would be to to limit the decimal places on the value field. It exports as 73.4851653145097 for example. It would be glorious to be able to chose how many (if at all) decimal places it will go to.
Just thought of something else. Adding a logging timer would be a big help too. The only timer that I found that works consistently with logging is the logic timer. If I want to have my input variable average out 100 records, but I only want my logging to run every 10 minutes I can't do this. I need to set the logic timer to 300000 so my logging only logs once every 5 minutes, but then my temperature won't be even because by the time 100 5 minutes rolls around, the average won't be accurate anymore. Maybe they're another way around this and I just don't know about it.
Actually setting the input timer to around 100 might fix the last issue.
