Having problems changing pages with buttons in Ride Runner. Sometimes they work, sometimes nothing and other cases I get screens blinking back and forth between views. I started with one variable, then tried a different variable for each case.
Code:
<command id="dayview" minimum_delta_vote_time="100">
<do function="Change Variable" functionTargetID="View_day" vote_opinion="1" vote_priority="Medium"></do>
</command>
<command id="nightview" minimum_delta_vote_time="100">
<do function="Change Variable" functionTargetID="view_night" vote_opinion="1" vote_priority="Medium"></do>
</command>
<command id="ledview" minimum_delta_vote_time="100">
<do function="Change Variable" functionTargetID="view_led" vote_opinion="1" vote_priority="Medium"></do>
</command>
</commands>
<executable_commands>
<external_COM_id id="RoadRunner.SDK">
<command internal_id="roadrunnercommand_nightskin" external_command="Execute">
<parameter order="0" external_command_parameter="nightskin"/>
</command>
<command internal_id="roadrunnercommand_dayskin" external_command="Execute">
<parameter order="0" external_command_parameter="dayskin"/>
</command>
</external_COM_id>
</executable_commands>
Code:
<if fire_on="logic" minimum_delta_vote_time="100" id="Dayskin_manual">
<boolean_operation type="equal to">
<parameter1>
<variable do="get" name="view_day"></variable>
</parameter1>
<parameter2>
<number>1</number>
</parameter2>
</boolean_operation>
<then>
<do function="Change Page" functionTargetID="Required Filler" vote_opinion="0" vote_priority="Medium"></do>
<do function="Change Variable" functionTargetID="view_day" vote_opinion="2" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="Nightskin_Manual">
<parameter1>
<variable do="get" name="view_night"></variable>
</parameter1>
<parameter2>
<number>1</number>
</parameter2>
<then>
<do function="Change Page" functionTargetID="Required Filler" vote_opinion="2" vote_priority="Medium"></do>
<do function="Change Variable" functionTargetID="view_night" vote_opinion="2" vote_priority="Medium"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="100" id="LED_Manual">
<parameter1>
<variable do="get" name="view_led"></variable>
</parameter1>
<parameter2>
<number>1</number>
</parameter2>
<then>
<do function="Change Page" functionTargetID="Required Filler" vote_opinion="1" vote_priority="Medium"></do>
<do function="Change Variable" functionTargetID="view_led" vote_opinion="2" vote_priority="High"></do>
</then>
</if>
My external commands to switch RR skins just disappear from the "then" statements when I run the software. I've been poking at this for days now. It worked last night, but when I tried it again this morning nothing would change.
