Converted the Light Sequencer program from Coding4Fun (
http://blogs.msdn.com/b/coding4fun/a...3/1230660.aspx) to work with the Fusion Brain (version 3) (
http://www.fusioncontrolcentre.com/) by Nicholas Vergunst and Tim Elmore.
The Fusion Brain v3, superseded by version 4 and soon v6, connects via USB and has, amongst other hardware, 12 outputs. I have connected these to
relays via ethernet connections (simple wire connectivity) to control the four
power plugs, from which the
lights gain their power.
Versions 4 and 6 have PWM capabilities, and the v6 boards will have 31 outputs.
I edited the original code to be less hardware dependent, placing all hardware operations in HardwareHandler.cs (renamed from PhidgitHandler.cs)
