Results 1 to 10 of 10
Thread: World land speed record.
    The land of polar bears and nekkid blonds
    Oh yeah, and I got the GPS screenshot to prove it
    Seems as if there is something wrong with the , . again, switching to period as decimal point made it OK again.
    133 is correct, but maybe rounding doesn't work.
    /M
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    hmm this is what i'm using
    Round(gps(7) * 1.852) which converts the gps speed into KM. Did this happen the moment you turned it on ? as the heading is still set at zero. I wouldnt of thought it would make much difference.. is it always displaying the 'land speed record mode' ?
    Setting decimal point to "," it's always there even when moving.
    Setting it to "." it's fine.
    But Gps(7) is that a string or a numerical value (datatype) ?
    round("100.9"*1.852) gives 1869
    round(100.9*1.852) gives 187
    /M
    Feb 2004
    Manchester
    Its a string. which it where the problem seems to be coming from. Let me have a play, should be releasing a new version today or tomorrow.
    CdR
    Well, this "feature" is back in ver. 0.52 Plus Plus Plus IIII ;-)
    /M
    Feb 2004
    Manchester
    I think this is down to your gps device giving out false info.. I have updated the nmea parser in the next release , so we shall see if it fixs it :-) Big update coming which includes lots of fixs, and also speedcams (this ones going to work)
    CdR
    Well, it's the same symptom as the previous time....
    Enter control panel >> Regional and Language Options >> Customize
    and switch "Decimal symbol" between , (comma) and . (period).
    That will be the differance between not working (,) and working (.)
    Same reciever as the last time, remeber the conversion with stings a few posts up.
    Looking forward to the new release though.
    /M
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hey CDR.. you should do a "testing" on the OS regional settings to check whether it is set to use "," or "." as decimal poit, or those string conversions will mess you up big time.. GPS standards always use "." (because "," is the field divisor).. but if the OS is set to use "," as decimal point, numbers like 123.45 will count as "12345" which is incorrect..
    You can detect comma as decimal point with something like: "if instr(cstr(1/2), ",") > 0 then" then you can fix it by replacing the "." in the string with a "," or by dividing it by the number of decimal digits * 10 .. like 123.45 / 100 (on a system with comma as decimal point it will yield to 123,45) ..
    Ride Runner RR's Myspace
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by guino
    Or you could just force the user to switch to the "." system
    In my carputer it won't be much of a problem since I can set it to "." without it affecting anything important, but on regular laptop usage it will be a problem.
    I do find it very interesting why M$ choose to ignore this problem,
    probably the best one could do is to make your own conversion
    function that returns the proper format regardless of wich symbol beeing used.
    /M
  1. Need LCD controller board from digital world wide
    By camarossguy2 in forum LCD/Display
    Last Post: 08-27-2004, 02:43 PM
  2. World Radio
    By NovaKane in forum General Hardware Discussion
    Last Post: 08-14-2004, 03:19 AM
  3. Super Mario World in C
    By Gutter in forum Off Topic
    Last Post: 07-09-2004, 01:57 PM
  4. Replies: 2
    Last Post: 05-17-2003, 02:58 PM
  5. What do you think of my playlist??
    By SkinnyBoy in forum Software & Software Development
    Last Post: 07-19-2001, 12:51 PM
