Results 1 to 10 of 15
Thread: Speed Camera Import
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    Speed Camera Import
    Imported the cams then went for a drive round to check it works, getting quite close to a cam that i know is on the DB.... Nothing, Drive through the cam... Nothing.
    a few mins later i get an error (cant remember exact error but will get it later) and freedrive quits. OK... reboot and re-oped FD, just incase something strange happes, after 5 mins, same thing, keep re-opening FD and same thing after a about 5 mins.
    the only thing i can think that it could be is the cam import, i remember CDR saying something about it updating every 5 mins, and that how often im geting the error, and ideas?
    Everything else works fine.
    Thanks.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Apr 2005
    UK
    Bump
    Type-R Mini
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    hi.. sorry just noticed this now.. If its erroring then there must be a problem with your cams.dat file. You can either delete it and import a new csv file, if your still having probs, then send me the csv file your trying to import and I will see whats causing it.
    cheers
    CdR
    Apr 2005
    UK
    Hey CDR,
    just tried again, same thing, error is:
    runtime error '13':
    Type Mismatch.
    CVS file im using is here, its the one off pocket gps.
    Thanks.
    Type-R Mini
    Feb 2004
    Manchester
    just checked.. you will need to delete the top line of the cvs file, the one with long/lat etc.. as its trying to import that as a camera.
    I would open the cvs file in excel and right click on the number 1 and choose delete and save. Sorry if you already know this..
    cheers
    CdR
    Apr 2005
    UK
    Thanks CDR,
    have done that and re-imported, no error as of yet.
    Type-R Mini
    Baz
    Baz is offline
    Feb 2005
    Leicester
    Where can I get the speed cam data download from????
    Or is it something I have to buy?
    Cheers
    Baz
    Feb 2004
    Manchester
    the uk one should of been included in the install.. if it wasnt sorry.. Grab the csv file that dan posted in post 4.. then just delete the 1st line and import.
    I'm working on improving this at the moment. should have something for you al lin a couple of days
    cheers
    CdR
    Apr 2005
    UK
    Had taken it off, just put it back and it has the top line removed
    edit:
    cdr, is it possible to change how it alerts you? it says camera detected at like 500 yards and flashes the speed cam icon, but can you make it re alert you at say 200 yards.
    also, what about speed? like in the csv file it has speed for a lot of them, would it be possible to make it give a further alert if you are going to fast.
    Thanks.
    Type-R Mini
    Feb 2004
    Manchester
    hi dan.. how it alerts you is as follows
    1st warning -
    400m from the speedcam it give a voice alert and flash alert that a speedcam is approaching
    2nd warning -
    300m from the speedcam this is what happens
    You will get a visual flash on the screen every second
    If you are doing over the speed that is stored in the camera it will also bleep every second.. if your doing below the speed stored it doesnt bleep. Your speed is checked every second.. so say the cam is a 30mph cam, and your doing 35.. it will bleep until you drop down to 30.. then it will just return to flashing.. if you creep up again to 31 it will again bleep at you :-)
    If however no speed is stored, you will just get the standard voice warning every 10 seconds.
    If when its in alert mode and you tap the screen it will turn off the voice alert.. and if you tap it again it removes the visual alert.
    saying this.. say you stop at lights or pull over, if your not moving towards the camera it will stop any alerts.. nothing worse than not moving and it flashing and bleeping at you :-)
    The best way to test this would be to add a false 30 camera down a 40mph road and have a play. I have posted a freedrive.exe update in the release thread which fixs a couple of problems, and i'm working on improving the speedcam bit at the mo..
    hope this info helps
    CdR
    o.. p.s if you look in the settings.ini file, at the bottom is where you can set the alert distance.. its in km. I will be changing these from .4 to 400 (meters on the next release.
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. GATSO Hunter v0.1 (Beta) - Standalone speed camera detection
    By Engram in forum Software & Software Development
    Last Post: 03-02-2005, 06:02 AM
  3. Speed / Red Light Camera
    By Skorpion in forum Map Monkey
    Last Post: 02-22-2005, 02:44 PM
  4. Destinator freezing when you approach a speed camera?
    Last Post: 01-31-2005, 06:37 PM
  5. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 08:13 AM
