Results 1 to 9 of 9
Thread: Still wrong address...
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hi CDR,
    I was doing some more testing today with the latest freedrive.exe patch and here is my finding... it appears some addresses are still navigating wrong...
    Trying to navigate to:
    City: S. Paulo
    Street: Escocia R
    House: 253
    wants to take me to: 286 Escocia R
    Street: Cristovao Diniz R
    House: 21
    takes me to: C Tv
    Ohhhh... I thought this was over :'(
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Poor Roy
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Yeah, also thought I fixed this.. I might of reverted back to a old version of FD source after trying a few things.. dont enter a house number for now, it should take you to the correct street.. also moved this thread the the bugs section :-)
    CdR
    Feb 2004
    Manchester
    ok, spent most of today trying to figure out whats going on here.. and the only result I can come to is that theres some incorrect information held in the brasil map. I have re-wrote my code several ways, all ending in the same result. In D3 you create a destination point. In this point are several items.. ie. Description, house, Street, City, Zip, Long and Lat.
    You build a point up from information, then ask D3 to fill in the rest.. so If I add street as Escocia R and city as S. Paulo, it goes off and finds the correct coordinates (long and lat). The problem comes when I add a house number, when I input house as 253.. as you know it then decides to go completely off route and somewhere else. What I cant understand is that it the same code that I'm using on all the other maps I have, and it works great. so.. at the moment it works fine when not using house numbers on your map.. sadly using the current map theres nothing more I can do.. I have tried including zip codes and double checking everything, but the outcome is still the same, your still leaving it upto D3 to route to that number which is causing the problem.
    The only thing I could suggest is trying a more upto date map, the one your using is dated Version 17MAR2003 which is over 2 years old. I am at present downloading one, I wont know till I get it what version it is.. but will keep you posted.
    cheers
    CdR
    São Paulo, Brazil
    Damn bugger.... I wonder why this is happening if it was working fine with MM... damn.... probably some stupid D3 internal working.... CRAPINATOR....CRAPINATOR....
    I'll live without house no. for now, and I'm going to try and find out if there is a map upgrade, but these maps were from an old PPC destinator program that was/is sold, and I thought there werent any upgrades. Can you confirm if you get a newer version maybe?
    Thanks!
    Feb 2004
    Manchester
    yeah sure soon as its downloaded.. may take a day... u know whatits like ;-p
    CdR
    sim
    sim is offline
    Low Bitrate sim's Avatar
    Jan 2005
    Gloucerstershire UK
    I don't know if it's related, but if I manually (ie when I am actually there) set my home location as a favourite called HOME and then use the go home button, freedrive routs me to a point about half a mile away on a nearby road. I'm using Q2004 map of UK
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
    Feb 2004
    Manchester
    this should all be sorted on the next release m8.. complete new address dialog.. for now if you wish, just use the save position on the menu, then type in home.. that will save your correct position for now
    CdR
    sim
    sim is offline
    Jan 2005
    Gloucerstershire UK
    Excellent worked a treat thancks m8
  1. Can anyone do any thing about this
    By Rob in forum Off Topic
    Last Post: 02-09-2014, 05:37 AM
  2. Way to trick computer into giving itself an ip address?
    By Question in forum General Hardware Discussion
    Last Post: 04-01-2005, 10:44 AM
  3. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum Power Supplies
    Last Post: 09-06-2004, 04:08 PM
  4. gamegear colour LCD screen useful??
    By asteroid in forum LCD/Display
    Last Post: 01-02-2002, 01:06 PM
  5. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum General Hardware Discussion
    Last Post: 04-27-2001, 03:51 PM
