I'm having the same thing.. starts in night mode with the day skin. Have to switch to day mode and back to nigth to actually get the night skin (using the ZdGrey skin)Originally Posted by Meelobee
Ive downloaded the newest version and I'm still having problems. I use Freedrive embedded in Roadrunner, both using my own ZdGrey skins.
The problem is: Freedrive always starts showing the night map in a day skin.
Is there any way to fix this?! thanks!
Good to hear im not insane and not the only one with this problem..But is CDR still reading this forum? Are you?!Originally Posted by t_bear
To change day/night skin automatically use GammaControl![]()
Yes, but GammaControl won't help with this problem, the skins appear to be loading wrong. You're just pimping your toolOriginally Posted by 0l33l
You might have named the day and night skins incorrectly
Or the button actions could be mixed up so day button runs night skin...
HTH
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
This is what I am finding as well, I am using the same skin so I thought it might be related. I took the default skin(which appears to be the same jpg for day and night) and put a D&N on the jpegs and tried it - same results. It does switch skins but you have to toggle to get them in sync. It maybe this is one of the only skins to have a day/night skin and why others are not noticing this issue.Originally Posted by t_bear
YupOriginally Posted by Meelobee
