WTB: 4-6" lcd
  • WTB: 4-6" lcd
    Im looking for buying a LCD:
    -vga
    -no need of touchsreen
    -~5" LCD
    thanks
    Project: The 1300$ geek van(1300$ for all, incl. the van cost)
    Planning: 50%
    Stuff: 20%
    Monney: __%
    Knowledge: 35%
    Up, modified my orignal post
    Planning: 50%
    Stuff: 20%
    Monney: __%
    Knowledge: 35%
      I'd possibly be looking for one or two of these as well.
      2003 Nissan Xterra Worklog
      Total amount spent so far: $1196.64
      You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
      2003 Nissan Xterra - Modifications
        look into buying a PSOne screen, moddable to support VGA, and cheap (like $35 at EB games)
          yes but they are too big :/ damnit!
          UP!
          Planning: 50%
          Stuff: 20%
          Monney: __%
          Knowledge: 35%
            UP!
            By too big do you mean depth, or the width/height measurements? Because the screen falls into your width/height requirements. The casing can obviously come off.
            And the people have cut the mickeymouse shaped circuit board to be a square smaller than the width/height of the physical screen. Last I heard, the only circuitry on the "ears" were the sound controls for the speakers and can be chopped off with only a few resoldered points. Worth looking into.
            1.9in x 2.9in -- 47mm x 73mm
              the height, i took apart my Mobile TV M5000 witch is a 5" and i just fits... i wouldnt imagine a PSone screen with its frame...
              Ya the casing can come of, but it has to be exactly the size of a 3.5" hdd to meet my requirements. Is it? Hmm, ya it worth another dig-in, if i could find info's on the net it would help, and photos...
              and btw, i never got any answer , check your pm man...
              edit:
              http://common.ziffdavisinternet.com/...i=91097,00.jpg
              hmm... doesnt looks like the board can be cut off...
              Planning: 50%
              Stuff: 20%
              Monney: __%
              Knowledge: 35%
                edit:
                Like 2k said, the wires can be relocated. That's only a ground, so there are plenty of other solder points for that wire. No big deal for that.
                  yes but to fit in my case, it would need to be cut like this:
                  http://img258.imageshack.us/my.php?i...9109700ln2.jpg
                  Planning: 50%
                  Stuff: 20%
                  Monney: __%
                  Knowledge: 35%
                    2K1toaster do you have any more info on cutting the PSOne board? I am thinking of using one as an intermediate (read elcheapo) step before going all out to a touch screen. Since the board is bigger than the screen I thought I would have to mount the board further into the dash and extend any wiring. Cutting down to size would be much better.
                    Carputer Haiku (thanks Ian Hughes)
                    Serious error.
                    All shortcuts have disappeared.
                    Screen. Mind. Both are blank.
                      MrJamieR, lemme know if you do it, lemme know your results.
                      Planning: 50%
                      Stuff: 20%
                      Monney: __%
                      Knowledge: 35%
                        Happy to agashka.
                        Serious error.
