FS: 3-way Components, Sub, Amp, and Wire!
  • FS: 3-way Components, Sub, Amp, and Wire!
    In my quest to get another car and failing to get a car loan, the audio system I designed for my Car has to go, I spend alot of time and money component matching these, im very positive that it will make a great SQ system for any audiophile...all items are new and warranties still stand.
    Audiobahn ABC6003Q Components:
    Carbon Honeycomb Cone
    Butyl Rubber Surround
    Chrome Plated Cast Aluminum Basket
    2 Layer High-temp ASV Voice Coil
    25mm Silk Dome Tweeter
    Surface or Flush Mount
    Component Matched 18dB Per Octave
    Crossover Network
    Complete With Mounting Hardware
    Audiobahn ALUM8P Subwoofer: (Note that it only requires .25 cu/ft of sealed space)
    PHAT 1.75 EPDM Rubber Surround
    Spun Aluminum Cone
    Dual 6 Ohm VOICE COIL
    Multi-connect Lug Lock Terminals
    Xtant 403a Amplifier:
    "Real World " 2 Ohm stability.
    12 dB Electronic Crossovers.
    Balanced Input sensitivity ( 100mV to 17 V RMS ) adjustable in 10 dB steps.
    Doubling of power from 4 to 2 Ohm loads.
    Forced air convection cooling.
    Four module ports which accept our plug-in modules.
    Fully discrete power amp.
    Fully regulated, PWM power supply.
    Hand-matched, complementary MOSFETs for better performance and sound quality.
    Independent amplifier channel gain adjustment.
    One line out accessory port which accepts our plug-in modules.
    Over-current and thermal protection circuitry.
    Passive rear speaker terminals with accessory port to accept Xtant's attenuation modules.
    Powerful Customization through Multiple Docking Ports.
    RCA line level outputs feed from balanced inputs.
    RCA Outputs.
    Selectable Balanced line inputs
    Three channel technology.
    Unbalanced input sensitivity ( 100 mV to 8 V RMS ) adjustable in 10 dB steps.
    I picked Stellar Labs Gold Plated RCA cables:
    KnuKonceptz Kablez, here is a list of my shopping cart:
    Item # Product Name Quant. Price Per Unit Total
    BC-1428 BC-1428 Kompression Fuse Distribution Block 1 $9.99 $9.99
    GMBT General Motors Side Post Battery Terminal 1 $3.99 $3.99
    RT4516BL Gold Plated 4AWG Ring Terminal -Blue 1 $0.99 $0.99
    FH-24 In-Line Waterproof AGU Fuse Holder 1 $6.00 $6.00
    AGU80 Gold Plated AGU 80 Amp Fuse. 1 $0.89 $0.89
    AGU60 Gold Plated AGU 60 Amp Fuse. 1 $0.89 $0.89
    KOL4P Kolossus Kable 4 Gauge Purple Power Wire 4 $0.99 $3.96
    KOL8P Kolossus Kable 8 Gauge Purple Power Wire 8 $0.45 $3.60
    KOL8S Kolossus Kable 8 Gauge Silver Power Wire 6 $0.45 $2.70
    SB4 Snap Bushing / Grommet 4AWG 3 $0.25 $0.75
    SB8 Snap Bushing / Grommet 8 AWG 2 $0.20 $0.40
    RT8516BL Gold Plated 8AWG Ring Terminal -Blue 2 $0.65 $1.30
    RT8516BK Gold Plated 8AWG Ring Terminal -Black 4 $0.65 $2.60
    FH-210 In-Line Waterproof ATC Fuse Holder 1 $1.49 $1.49
    KAR10BLS Karma 10AWG Speaker Kable 5 $1.15 $5.75
    KOL18BL Kolossus Kable 18 Gauge Blue Primary Wire 5 $0.05 $0.25
    Sub Total: $45.55
    Tax: $0.00
    Shipping: $7.50
    Discount: $0.00
    Total: $53.05
    I am asking 500$ shipped o.b.o. above 450$, if your cousins girlfriends big brother's roommate can get you this setup for less, than feel free to take that route, Everything was purchesed from an Authorized Dealer, I even got 40% off on the Audiobahn products cause I know a guy who works for www.thezeb.com, so if you dont like the price, please keep it to yourself, pictures of the actual product can be supplied but are for the most part exact replicas of the above pictures, just mine are sitting in a closet...send PM's or E-Mails to [email protected]
    Thats a pimp setup. I would take it if I had the money, but I just bought some Cerwin Vega stuff. Damn it.
      I would lik just the comps and the sub if u want to seperate them. How long were they used for? LMK
        Nothing has been used, it is all still in the box in my closet, I bought it all for my Fiero, but I am selling my Fiero. I opened the boxes to all of them to make sure everything was in good condition, I noticed that the blue acrylic that goes over the crossover was off on both crossovers, I thought something was wrong, so I called Audiobahn tech support and they said it comes like that and to just open up the crossover and put them back on, so I did, and everything is nice. I might be interested in splitting up the components and sub.
          Hell, while im at it, I might as well throw my car up on this forum, I hope its legal, if not just delete the post.
            bump
              This would be so awesome for my Dodge, but I'm in the process of moving and can't acquire any more things right now. I would love to have this though.
              "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
              By "ToneRiddle"
                Lol, you live kinda close, you wouldn't be moving because of the Hurricanes would you? Anyways, I might still have it when you get settled down, just pm me or something =)
                  well sorta yes and sorta no, we are moving cause of hurricanes like Ivan, but mainly cause I'm gettin out of the Marine Corps. Don't want to hijack your thread, just thought I'd give ya another bump. If you still got it when I settle down in a month and a half, I'll probably buy it from ya.
                  By "ToneRiddle"
                    your not hi-jacking =), I initiated the conversation =) Where are you moving to? Good luck with the move! Bump for me!
                      BuMp
                        bump
                          bump
                            $250 and ill take it
                              Lol, stay out of my thread please =)
