FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
  • FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    Im selling some parts I dont' need anymore because I just put a radio in the car. The sound blaster is two months old and I have the receipt along with all original packaging. The sound blaster gives you all the abilities of controlling the sound in your system, equalizer, bass and treble controls, everything. It really is amazing. The amp is a 300 watt 4 channel pioneer amp in perfect working, and perfect looking condition, not a scratch. The amp is perfect for running any car stereo, it ran my RL with 8 speakers without any problem, and has alot of features and adjustments. Comes in original box and instructions.
    4-Channel Bridgeable Amplifier (GM-4000F) - $73 non negotiable
    Stole Amp Info From Ebay:
    High power and high-quality sound go hand-in-hand with this Pioneer 4-channel bridgeable amplifier. Its sturdy, durable design is versatile yet stylish. The MOSFET driven power supply is able to drive 4 separate speaker channels as well as difficult multiple subwoofer leads for distortion-free sound.
    Key features GM-4000F
    Bridgeable 4-channel capability 4 x 70 W or 2 x 150 W (Max. Power)
    Continuous output power: 4 x 35 W or 2 x 70 W (4 ?) 4 x 40 W (2 ?)
    4 x 45 W or 2 x 100 W (4 ?) DIN Power (DIN 45324, +B = 14.4 V)
    Load impedance capability (2 — 8 ?)
    LPF/HPF network (A and B ch): 80 Hz, -12 dB/Oct
    High Voltage Input capability (400 mV — 6.5 V)
    Features GM-4000F
    PWM regulated MOSFET power supply Yes
    Input level/gain control Yes
    Load impedance capability 2 - 8 Ohm
    RCA terminals Yes (input/output)
    Power / ground terminals Large screw-type
    LPF/HPF Network 80 Hz
    High performance balanced isolator circuit Yes
    Speaker level input (A and B channel) Yes
    Specifications GM-4000F
    DIN power output (W)
    (DIN45324, +B = 14.4V) 4 x 45 W or 2 x 100 W (4 ohm)
    Cont. power output (RMS),
    14.4V (20-20kHz/4ohms) 4 x 35 Watt or 2 x 70 Watt
    14.4V (20-20kHz/2ohms) 4 x 40 Watt
    Frequency response 10 Hz - 50.000 Hz
    Distortion 0,008 %
    S/N ratio 100 dB
    High Voltage Input Capability 400 mV - 6.5 V
    Max. current consumption (A/4ohms) 18.1
    Chassis size (W x H x D) 300 x 61 x 237 mm
    Sound Blaster Live 24 Bit: $35 delivered priority mail
    Newegg Info and Reviews
    Improved Music Quality
    Enjoy Crystal Clear 24-bit Audio
    With 256 times the resolution of your basic built-in sound, all your music, movies, and games will sound better in 24-bit ADVANCED HD™ quality.
    Create MP3s, Organise Music, Burn CDs
    The full-featured Creative MediaSource™ digital player allows you to make high
    quality MP3s, manage your music library, and burn personalised CDs.
    Make Your Music Sound Even Better
    Customise your CD and MP3 playback with easy-to-use and convenient
    Acoustic Enhancements that give you better control over your music than a home theatre system.
    Bass Boost - Enhance the bass in your music (2.1 and 4.1 speakers only)
    10 Band Equaliser - Personalise playback of audio frequencies
    Audio Clean-Up - Remove noise from MP3s of old recordings
    CMSS® 3D - Enjoy virtual surround sound on stereo speakers/headphones
    SVM™ - Automatically match volume levels across music tracks
    EAX® Effects - Add acoustic effects like Concert Hall to your music
    Convert Old Recordings to MP3 Easily
    Record all of your old cassette tapes and vinyl records to MP3 with simple
    connections and easy-to-use recording software with advanced cleaning tools.
    Send me an email or instant message, and I will get back to you asap. I have paypal and have been on there for a long time. I also take cashiers checks and money orders, and will give you a 5% discount for using a check because I hate giving paypal more money.
    later,
    Kenny
    Check out the new setup up soon
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
