FS: Rockford Fosgate Subs/AMP - ALPINE Speakers
  • FS: Rockford Fosgate Subs/AMP - ALPINE Speakers
    FS
    1 Alpine CDA-9847 HeadUnit .. SOLD to lime
    1 RF 900w monoblock amp
    2 RF Stage 2 Punch 10" DVC Subwoofers
    1 Alpine Type-R 5x7 Component Pair
    1 Alpine Type-R 6x9 Pair
    Each of the four listed items are 70$ shipped each in the US.. extra for other countries... or 300$ shipped for the lot now deck is gone
    The subs also are currently mounted in a ported Q-Logic box which is for sale too if desired for 20$+ whatever shipping is.
    Subs and speakers purchased end of March 06 at Best Buy. Have extended warranty, need to read if it is transferrable. Amp purchased at Best Buy few years ago. Older model, actual picture not uploaded, but here is link to same amp. http://i24.ebayimg.com/05/i/07/a9/3a/6b_1.JPG
    PM/Email at setyte@gmail.com or AIM at maddmarshall2k
    This is basically a full system. Arguably it needs a 4 channel amp to make the Type-R speakers really shine. They sounded great to me without an amp, if you choose to pick up an amp they will be even better.
    subs a model p210d4 so punch stage 2 dual voice coil 4 ohm 250w rms 500w max
    subs / alpine speakers purchased march 31 for 119.99 each... used from then through mid june when i bought a new car which i have not put the system into. subs are 70$ shipped if you split them... 120 shipped for both... im negotiable on prices though I'm sure if you check ebay you'll find them to be on par
    Ygpm
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
      link for specs on amp?
        tryign to find them... its an older model... im having trouble finding an archive of RF amps
        ok i finally know the model ... it was very small... 301m... states 900w... looking for spec sheet now
          http://www.rockfordfosgate.com/scrip...ted=1083265782
          thats what i found... pdf... excerpt from page 10
          SPECIFICATIONS
          MODEL PUNCH 301M
          Maximum Power Rating
          All Channels 900 Watts
          Dynamic Power Rating - Measured at 14.4 Volts
          Mono into a 4Ω Load 150 Watts
          Mono into a 2Ω Load 300 Watts
          Signal-to-Noise Ratio >100dB A-weighted
          Crossover Slope 12dB/octave Butterworth
          Crossover Frequency variable from 50Hz to 250Hz
          Crossover Type variable AP/LP
          Dimensions: (with Endbell)
          Height 2.38" (6.05cm)
          Width 9.85" (25.02cm)
          Length 12.07" (28.12cm)
          Frequency Response 20Hz to 20kHz ±0.5dB
          Bandwidth 10Hz to 100kHz ±3dB
          Damping Factor @ 4Ω (at output connector ) >200
          Slew Rate 30 Volts/ms
          IM Distortion (IHF) <0.05%
          Source Unit Compatibility (+15dB gain overlap) 17V max. (low level in)
          Acceptable Signal Voltage Range Variable from 100mV to 6V (RCA Input)
          Variable from 0.5V to 11V (High Level Input)
          Protection NOMAD - Internal analog-computer output protection
          circuitry limits power in case of overload. Thermal
          switch shuts down the amplifier in case of overheating.
          Battery Fusing Rates (External to Amplifier) 30 amps
          Fuse Type ATC
          Equalization (Punch Bass) Switchable from 0dB to +6dB to +12dB
          Input Impedance 20k ohms
            payment sent for the head unit.
            thanks
              any pics of the amp? any scratches on it at all? interested in that and the 6x9s
                placed head unit in usps's hands a few hours ago... will post pictures of amp soon as camera charges up enough.. dont see a single scratch on it
                  Its just dusty.. no scratches... if need be i could wipe it down prior to shipping.. i live in vegas... in a particularly dusty area.. amp is in full working condition... pumps out the jams like it were hott off the line.
                    I just sent you another email - I'll take the subs. See my email.
                    Thanks.
                    Sara - I'm a geek from the word go!
                    2004 Nissan Titan
                    2004 Mazda3- Plans: Mac Mini, LCD, etc.
                    Previous Cars: 1999 Camaro- Alpine HU, Polk Comps, 2 Alpine 12" subs, custom encl
                    DON'T BUY FROM SETITE - HE'S DIRTY!
                      Thanks.
                      already shot you an email in reply... subs are yours
                        Woo hoo! Thanks for the quick replies!
                        2004 Nissan Titan
                          got your payment.. will shoot subs off tomorrow
                            Bump for a good seller, and buyer. Great equipment!
                            - Chris Williamson
                            Interior Technology
                            '02 Ford Ranger
                            '68 InvaderGT - Custom Kit Car
                              I sent you an email but in the past you said you didn't get my emails so I'm posting here as well.
                              My package was damaged - I refused it. The styroform was completely broken down and the subs were rattling around inside. I turned the box to take a picture and we all heard a big THUD when the subs went from one side of the box to the other. I could see the subs from both ends of the box without opening the box at all. I've PM'd & email'd you my phone number. Call me to work out the refund details ASAP. I don't know if this is poor packaging on your part or damage on UPS's part and to be honest, I don't care. I just want my money back. I got the tracking # from UPS if you need - you can put in a complaint with them & try to get some $$.
                              2004 Nissan Titan
