2007 Honda Accord coupe V6
  • 2007 Honda Accord coupe V6
    Black with black leather.
    5k miles.
    Auto, dual air, leather, satellite radio, sunroof, 17inch rims, 6 disk changer, tinted windows.
    The car is in perfect shape. I just bought this about 2 months ago.
    I drive about 100 miles a day highway to work.
    First oil change was done at 3100 miles showing 60% oil life left.
    I have installed a full audio system with all rockford fosgate components.
    2007 Accord coupe EX-L V6
    car2pc adapter
    scosche slc4 line converter
    xenarc 7tsv screen
    RF door spkr 6.5 t162c
    RF rear spkr 6x9 p1694c
    RF amp 4ch p325.2
    RF amp 2ch p450.4
    RF 4g wiring kit cp4dcks-06
    RF subs 12' p112s8 (2)
    Q-logic sub box qlh12d125
    Speaker wire 50'
    + the car PC
    2.4ghz, 512 ddr ram, 250gb hard drive, cd-rom, bluetooth, linksys 802.1b wireless
    I have all the receipts for the stuff that is over $2000 worth. The steering wheel controls even work on the PC and stereo still.
    The CarPC uses a 7 inch touchscreen that is in the lower cubby pocket.
    It has everything. Windows XP, wi-fi internet, bluetooth, touchscreen, 250gb of music and movies.
    More pics can be found here.
    http://www.we-todd-did-racing.com/browse/john07ex/50136
    The window sticker is $30,035. Which i have still.
    I am asking $27,000 with the PC and stereo system.
    Email me at [email protected]
    Car is located in Central Florida. No problems at all.
    EX-L V-6
    • 244-hp, 3.0-liter, 24-valve SOHC VTEC® V-6 engine
    • Drive-by-Wire™ throttle system
    • 5-speed automatic transmission
    • Double wishbone front suspension
    Vehicle Stability Assist™ (VSA®) with traction control
    • Dual-stage, dual-threshold front airbags (SRS)
    • Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS)
    • Side curtain airbags
    • Anti-lock braking system (ABS)
    • Daytime Running Lights (DRL)
    • Cruise control
    • Power-assisted ventilated front disc/solid rear disc brakes
    Electronic Brake Distribution (EBD)
    • 17-inch alloy wheels
    • Dual-zone automatic climate control system
    • Ambient console lighting
    • Power moonroof with tilt feature
    • Heated power side mirrors
    • Leather-trimmed interior
    • Dual chrome exhaust finishers
    • Heated front seats
    • HomeLink® remote system
    • Illuminated steering wheel-mounted cruise/audio controls
    • Driver's seat with 8-way power adjustment
    • 120-watt AM/FM/6-disc in-dash CD audio system
    • XM® Satellite Radio†
    http://automobiles.honda.com/models/...ory=EX-L%20V-6 Link to Hondas website for more details.
    Here is a better pic of the car.
    And the computer screen.
    10 acura TL tech
    10 BMW S1000RR
    Did you have any problems with the Car2pc adapter? Did you have to modify it at all? I have an 03 accord, and i cant get either the computer, or the HU to recognize it.
    03 Accord coupe
    2.4 ghz media pc, DSSC, 200w Inverter, xenarc 7inch ts.
    Parts: 75%
    Install: 75%
      Yes im using the car2pc adapter. Remember it is USB that will need a long extension to reach your PC and also it will use the AUX in to the back of the radio.
      worked great out of the box for me
      10 acura TL tech
      10 BMW S1000RR
        The connection i used was on the bottom of the head unit. You say you found it in the back of the head unit? Do you have the same all-in-one cd changer? i.e. there is no other component for the changer?
        03 Accord coupe
        Parts: 75%
        Install: 75%
          John why on Earth are you selling the car, it's so nice especially the clean carputer setup and all the audio equipment. For anyone interested the car is in perfect condition when i bought a power supply from him just yesterday.
            Hey navyguns i PM'ed u my cell if u still need some help with the car2pc adapter.
            And yes there is one AUX in on the bottom passenger side on the back of the in dash changer tuner.
            10 acura TL tech
            10 BMW S1000RR
              I appreciate that john, but i got in touch with car2pc, and they are going to send me out another cable. I also noticed that when i opened the case on the adapter, the chip wasn't seated properly. I took it off, and noticed that it was insertered backwards. They are sending out a new cable, if that doesnt work, then i will have them replace the box and go from there.
              03 Accord coupe
              Parts: 75%
              Install: 75%
                Oh i thought you might find this interesting, this is my honda, NEARLY identical to yours, but yours is alot newer. Mine's an 03. The monitor was fabricated into the flip up center compartment, and i was able to keep the flip up cabability, so i will be able to mount a dvdrom right behind it later on.
                and yeah, i know, the finish on the bezel isnt perfect, but for now it will do.
                03 Accord coupe
                Parts: 75%
                Install: 75%
                  Wow, kept the flip up, that is nice. Still spring loaded?
                  Mike M
                  2006 Accord VP Sedan
                  My worklog
                  http://www.mp3car.com/vbulletin/work...-dads-car.html
                    it is a little bit, but the monitor due to size, wont go all the way up like it used to. just not enough space, and the cables kind of get in the way. it does go up just enough that i will eventually be able to mount the drive in behind it for easy access.
                    03 Accord coupe
                    Parts: 75%
                    Install: 75%
                      A follow up to my issue with the Car2pc adapter, i received in the mail from them, a new cable to connect it to my head unit, and they sent me a firmware upgrade, i dropped the ic in, and connected, and now the sound works flawlessly. the sound is great! i do get a slight buzzing when the computer is off during operation and the head unit is on the aux port, but i am not even worried about that.
                      03 Accord coupe
                      Parts: 75%
                      Install: 75%
