FS Entire System, Everything for $1100.00
  • FS Entire System, Everything for $1100.00
    Here are the Specs
    7" transflective screen (Xenarc widescreen with remote)
    ------------THE PC--------
    Via C3 1Ghz CPU
    512 MB Ram
    80GB HDD 2.5"
    VIA EPIA PD 10000 mainboard
    6 USB, 4 serial ports
    SB Live 64 sound card
    Caseoutlet Travla c137 case, black
    M1-atx 90W pwr supply
    The following hardware will be included
    -80mm external exhaust fan on top of the chassis cover (keeps the entire system cool, blows hot air from the pc out through the top of the case)
    -XM Direct unit, inside the comp chassis, with cabling for serial port and power, with the antenna
    -RoadRunner temp monitoring hardware with 2 temp probes
    -All wires with molex connectors
    -External USB cd\dvd drive with wiring
    -external Holux GM-210 USB GPS reciever
    The following software is preinstalled
    WIndows XP pro
    Registered copy of StreetDeck, with mappoint 2006(No cds)
    about 5 GB of mp3's, all sorts of music
    1 2 channel AMP
    Power Acoustik 500 Watt
    All power connections run off the m1-atx so you will get clean power to all the components of the pc, including the monitor and the dvd drive.
    You will get all the cabling, usb, power cables, and anything else that i used to install.
    All this for $1100.00. I am not parting this system out. I can take detailed pics of the system. Check out my sig for the install pics as well as the transflective screen. There are links there.
    This is a rock bottom price guys. Its the real deal.
    SO CAL BUYERS PREFERRED! The price does not include shipping which would be pretty darn expensive for all this stuff. Esitmated shipping cost is about 200.00 for UPS ground.
    Civiputer: Dont have one anymore, but here is what is used to be!
    offering $20 for the temp monitor and probes
      are you sure you wont part out that transflexive xenarc?
        A complete system is much easier to sell. Not going to part it out.
          Bump
            Why are you selling this system? Seems like a great setup.
            I am looking to build a fully loaded carputer (but in a truck). I wouldn't need the amp in this list because I'm going to just go with my stock Bose sound system. Also wouldn't need the XM stuff. If I'm going to have gigs of songs on the carputer, why have XM?
            Have you had any problems with any of it?
            Did I read it right and you did some custom work to the screen? I would put this into the dash or console (I can't decide) and I don't want a screen that is customized to the point where I can't use it.
            Also can you put up pics of the case?
            2003 Silverado Ext. Cab Z71 - Just getting started...
              Im selling the car therefore Im selling the system. You cannot use your stock BOSE system unless there is an auxiliary input jack on it. Otherwise, you will need some amps. I have not had any problems on it at all. The screen was modified so that it can be seen in direct sunlight. Also, the screen housing has been removed (most if it anyways) so you would need a mounting for it that covers the areas which are not visible. I can take pictures to explain what I mean. I will post pics of the case asap.
                Here is a pic of the PC Case along with the 80MM fan installed on the top of it to help keep the whole system cool.
                  Here is the monitor in bright sunlight
                    Why Is Shipping $200.00. Are You Shipping The Whole Car Too.
                    New Age Garmin - Skin for RR
                      Shipping is expensive. The more weight, the more it costs. If I were to pack all the equipment, cables, amp, etc into a box, or several boxes it would cost a lot. If you dont believe me, check out shipping prices at UPS.com. Remember, shipping is billed by size of carton and weight.
                        I had a 100lb bean bag sent ups for $89.00. It came in a 3ft tall box that was about 2ft by 2ft. Your shipping estimate is a little high. I ship a lot of stuff, and $200 for shipping is way over estimated. $100.00 is more reasonable but probably a little high yet. your entire system cant be over 50lbs and I imagine if you send in two boxes you should be able to pull off shipping for a pretty good value. Especially UPS ground. Just a tip for you. Not trying to bag on you.
                          You may be right. I am going by experience I had shipping a radio control Truck. The box ended up weighing about 65 pds and 36" square. Cost me 167.00 to ship via UPS ground. It may have been less if I packed it myself, but I felt that I was raped. LIve and learn I suppose. Its just an estimate in any case. If the shipping for the entire system is less, i would not charge any more than it costs.
                            Sort of like the AMD/Intel thing, but I find that domestic shipping ground, FedEx is faster and cheaper than UPS. Every computer I sent through UPS has been returned in shambles. One even had a tire track on the box
                            But 36x36x36 box weighing 30lbs was $50 ground FedEx. It would have been over $120 UPS Ground.
                            1.9in x 2.9in -- 47mm x 73mm
                              This system is still available... Taking any and all offers. Southern California residents preferred but will ship within CONUS
