"What's going on with the forum?"
  • "What's going on with the forum?"
    UPDATE: Issues mentioned as of 4/23 should be resolved. Please inform if you find otherwise.
    Yes, we are aware of a problem.
    It is due to the fact that the uninstall instructions for the Zoints profile system were not accurate.
    We are still working on the main page access (http://www.mp3car.com/vbulletin).
    Untill then, you can still access the forums through sub forum links.
    Thank you for your patience.
    Jan Bennett
    Not meaning to tell you your business...... but test platforms are handy before any major changes.....
    I say this as a PM who deals with large corpate networks with large enviroments.....
    Terran
    My Project Site
      FYI, search is broken.
      ODYSSEY
      Originally posted by Tidder
      Digital-Car UK|
      (\__/)
      (")_(")
        This was an uninstall..not an install that went south.
        Jan Bennett
          When does anything ever uninstall fully or correctly?
          ODYSSEY
          Digital-Car UK|
          (\__/)
          (")_(")
            Uploading images via the User CP is broken..
            The database insert goes all wonky.
            I have 2-3 blank "images" in my list that I can't delete, because it says it can't find the files.
            Can someone get rid of those?
              search.php has been fixed.
              please continue to report any oddities
              -- WireSix, Inc. --
              MP3Car Lives Here!
                we're restoring from a back-up.
                Jan Bennett
                  User CP: Settings & Options
                  I'm not sure if it's related, but I can't seem to do any of the "Edit" functions in the "User CP: Settings & Options". When I try to Edit Signature/Profile/Avatar/etc, I get the following message: "Undefined authentication type".
                  Cheers,
                  Long.1
                  Worklog: 2006 Ford Territory Ghia (Melbourne, Australia)
                  Mounting Components in Custom Carputer Box
                  Attention Aussie's - Say G'day Here
                    Cheers,
                    Long.1
                    Yup, me too.
                    The restore from backup, presumably of the UI, will probably fix that as well..
                      Also, I noticed that the WYSIWYG icons on IE7 don't seem to work..
                      Like the Insert Link button pops up
                      http://www.mp3car.com/vbulletin/sugg.../ieprompt.html
                      with "page not found".
                      This was happening for some time it seems, before today's break..
                        Same thing.... thats why you need pre production / production areas so you can test before making changes in your enviroment.
                        'Change Managment'
                        Terran
                        My Project Site
                          Thanks for the suggestions ccsnet, I knew you would be in here with them.
                          However, I don't have control over that aspect of this company.
                          Jan Bennett
                            You can use this example as a reason for a dev environment to see how changes work prior to putting the change in front of us.
                            Better for business to reduce the user population from seeing this when possible.
                            Not picking on you, attempting to suggest a way to improve. This type of conversation is one I deal with daily (professional software QA).
                            Cheers and glad you are getting things worked on.
                            TruckinMP3
                            Read the FAQ!
                              I'm not quite sure how to take that first line.... re the 2nd line ... if your supposed to be the one maintaining the forum and adding to it can I suggest you bring this up asap..... I'm pretty sure FirberOptic used to test every thing...
                              Terran
                              My Project Site
