Code Tags Not working correctly
  • Code Tags Not working correctly
    The [CODE ] [ /CODE ] tags are cropping the text if it is too long. There is a scrollbar on the bottom. Since the "yellow-ish" part extends the correct table width, I am not sure why there is a frame inside of it with a fixed width. Looks pretty bad IMHO.
    1.9in x 2.9in -- 47mm x 73mm
    looking into it.
    thanks for brining it up.
    Jan Bennett
