php.ini forum problems
  • php.ini forum problems
    Do you have access to the PHP.INI file on the server this site is hosted on ? The memory needs to be increased to get rid of this:
    Fatal error: Allowed memory size of 8388608 bytes exhausted....
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Frodo
    nothing that I can fix
      I own the server... there isn't any reason a script should want more than 8meg of memory.. this is a freaking forum. The reason its erroring out is because of some sort of run away loop thats eating all the ram.... its not a php/server issue mind you this is a BETA release of vbulletin.
      -ryan
      -- WireSix, Inc. --
      MP3Car Lives Here!
        regardless, this is a very annoying problem that happens VERY often, and increasing the amount of memory seems to have solved the problem for many people.
        Never hurts to give it a try....
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          thats bad logic... if you've got a memory leak in an app you don't simply put more memory in your box to compensate
          -- WireSix, Inc. --
          MP3Car Lives Here!
            true, but from what I've seen, this "leak" fixes itself, increasing it a tad would at least reduce the problems to happen less often.
            also, if you want to get picky, running a production server on beta software isn't good logic either....
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              hey don't point fingers at me thats bg
              -- WireSix, Inc. --
              MP3Car Lives Here!
                Ok, end of discussion, I don't want to start an argument.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  I had to bring this thread back from the dead because someone deleted it?
                    I did jackhole
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      Yes and this problem still remains. Its a pain the hole to search the forums now without getting any errors.
                      What im curently listening to.
                      My complete carpc setup
                        Sorry for all the errors, I find them annoying too and I think thatís why the emails arenít working either. There was a communications mix-up between Bgoodman and myself. When I told him to install that update to vBulletin, I meant the latest 2.x release not the 3.x Beta. Unfortunately the database has already been converted and there is no way to revert back to a stable release. Short of losing all the data and starting fresh we have to wait for a stable 3.x version to be released. Iím sorry there isnít a better answer.
