2.0, 4 port USB hub question
  • 2.0, 4 port USB hub question
    I got a 2.0, 4 port, USB hub and I hooked it up...plugged in my netgear 802.11b usb wireless drive...it doesnt want to pick it up...any suggestions?
    anyone?
      You might want to give people a little longer than 14 minutes to reply, and putting this question in the correct subforum may help out. Try the General Hardware forum.
      99 Ford Ranger - Bagged and laying frame
      Current Carputer project:
      Done:
      Custom mounted 7" LCD w/ TSK in radio bezel
      Custom center console for relocated headunit
      Via Epia M10000
      GPS
      MP3
      OPUS PSU
      DVD
        well it was around the time that all the other threads bumped mine out and reset...
          it's cause it's in the comments about the website thread
          people don't usually look in here go post this question in the general hardware section
          CarPC Status:
          GPS: 99%
          Hardware: 99%
          Software: 92%
          Case Install: 99.9%
          Dash Install: 100%
          Car Install: 72%
            ...it's probably because there isn't enough power for the drive. Try plugging the drive in directly to your comp and see if it works. I assume the hub is unpowered.
            1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
            PC built into console
            worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
            Some of my music: http://www.myspace.com/markquestion
              yups sounds like a power issue. If the hub has a power socket try getting some power into it.
