What fields would you like to see?
  • What fields would you like to see?
    I'm working on a mod right now that will list all of the equipment you are running in your car for your CarPC.
    So far I have the following (not necessarially in this order):
    Motherboard
    Processor
    Memory
    Hard Drive #1
    Hard Drive #2
    PSU
    Screen
    Sound Card
    Satelite Radio
    WiFi
    EVDO
    Front End
    OBD-II
    Operating System (incl. modifications)
    GPS reciever and software
    Radio Tuner (AM/FM)
    Miscellaneous (phidgets/software/etc.)
    What else would you like to see?
    Jan Bennett
    GPS receiver/software.
    Installed.
    -GPSSecure- - GPS Tracking
      Motherboard chipset
      Radio Tuner (if any)
      Car audio hardware (headunit, amps, EQ, etc.)
      Other hardware (phidget boards, custom hardware, etc.)
      Internet connection (other than WiFi adapter like cellphone & provider)
      Other software besides frontend (MBM5, PhoCo, ECU tuning, etc.)
      How about the Wiki?
        DOH!
        completely forgot that one...lol
        Added!
        Jan Bennett
          Originally posted by DarquePervert View Post
          Motherboard chipset
          because I'm worried we will already have a long list, I'm going to leave this out. If you post your mobo, this can be easily found.
          added
          I think I'll save this for a second page if possible. Since this board focuses mostly on CarPCs, I'll start there. Once I have this part done, then I'll see if I can add a second page with this information.
          will add a miscellaneous field that's more than a single line.
          I have this under EVDO.
          I'll mention this in the miscellaneous section!
          Thanks for the help guys!
          Jan Bennett
            maybe not listing all the audio end, but more like a stock or aftermarket check box?
              ok - now I've added a drop down under my name - once you fill out the specs in the user CP, this drop down will show up - I have it set as a conditional...if you have something in the motherboard field then the pop-up will show up, if you don't have something in the motherboard field, then nothing will show up.
              Figured that the one spec that most anyone would fill out would be the mobo field...thoughts?
              also, I haven't listed off all of the fields in this drop down, else it would be wayyyyyy too long...
              keep in mind that I'm still working on all of this, so it's still going to change some
              once I've got this done, I'll look into adding another page, and how to do the check box (maybe if you have the box checked for aftermarket then it enables the aftermarket audio page?)
              Jan Bennett
                Looks interesting, not sure about the colouring at the moment.
                Goes off to find said fields to fill in.
                  ha, beat you too it looks cool I think..... really nice addition
                    Bah! Humbug.
                    PS Red, now you're an admin, can you fix my custom title back to Confusion Master which I had before some previous forum upgrade?
                    Pretty Please.
                      Cool! Great job on a kick butt Mod!
                      openMobile - Download
                      Like what you see? Donations are always welcome
                        That mod is pretty cool, it's looking better then I thought it would. I wonder if we can create a drop down list for the most common items.
                          It would look better with a transparent background I think (the box you click on), as it wouldn't look slapped on there, just my opinion.
                          Good mod, that's for sure!
                          List of front-ends/usefull apps
                          XTroniC | XTroniC Direct
                            Originally posted by Enforcer View Post
                            Bah! Humbug.
                            Pretty Please.
                            Jan Bennett
                              Are you talking about in the profile fields while you're filling it out? That I'm not sure about.
                              I was wanting to do something similar to that as I felt it would make searching on those fields that much easier...since it would be a common syntax. However, editing code to that level is above me at this point...lol
                              regarding the color...I agree, it looks a bit misplaced in the 3.6 skin. However, it's not soooo bad on the 3.5 skin.
                              I'll see what I can do to fix it.
                              Jan Bennett
