what type of epoxy\glue?
  • what type of epoxy\glue?
    I need some suggestions for PERMANENT installation.
    I need to know what would be the best appropriate long-term epoxy\glue suggestion to apply to the underside of a vehicle's main frame to attach steel wire onto for holding up LED lights.
    I also need suggestion for doing the same thing for the wheel wells as well.(i do not know if you can use the same glue, that's why i asked this too).
    I dont know what to use but i know what i need.
    I need an epoxy in gel form because all work is done vertically so cannot have any "dripping" epoxy at all. I just do not know what to use.
    Again, i need something that will last for a LONG time. Resistant to solvents, water, ice, salt, dirt, oil, grease, etc...
    IF you are attaching metal wire to metal on the vehicle, then use JB-Weld.
