What homebrew PVR do you use?
  • What homebrew PVR do you use?
    I know about MythTV, pcHDTV, Media Portal, and Freevo, but I'd just like to check my options out there. What do you use and what are your results?
    Jan Bennett
    Freevo : simple, efficient, lightweight compared to MythTV but has less options.
    MythTV: powerfull, heavy but nothing is missing in it.
    It depends on which machine you set them.
      ATI HDTV wonder
      screen name here use to be MegaloRESE15"
        Gb-pvr also Meedio...
        2002 Mitsubishi Galant
        Carputer Specs:
        Via M10K
        512mb Ram
        60GB HDD
        Souund Blaster Audigy2 NX
        OPUS ITX PC Case
          BeyondTV with 2 HDHomeRun's for unencrypted QAM recording plus 2 Hauppauge PVR cards for DirecTV recording.
          Z
          Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
            I had a MythTV box, but just upgraded to a satellite tuner with 100hr DVR built in. (No extra fee or anything). The thing is, MythTV recordings were unreliable because the satellite receivers we had and still have are only controllable via IR. So a IR transmitter next to the receiver is not very reliable. This means you record the times you want but the wrong channel!
            It had nothing to do with MythTV, but control of your cable/satellite box is key to a happy DVR. Other than that, I like'd its interface, but overall the all in one unit is much nicer. Although I cant customize it very much. Oh well.
            1.9in x 2.9in -- 47mm x 73mm
