Batch File
  • Batch File
    I'm trying to write a batch file to delete the contents of my temory internet items folder on bootup, however I'd like it to keep a couple of cookies for obvious reasons.
    This is what I've got so far:
    Code:
    del c:\Windows\Tempor~1
    undelete c:\Windows\Tempor~1\rob@www.mp3car.com/
    undelete c:\Windows\Tempor~1\rob@www.minimania.com/
    Now here are the problems:
    1) Can't find the folder, I believe I've got the DOS name correct, and I've been able to delete the contents of other folders no problem.
    2) It prompts me for a key board press of y or n before it will delete the contents of the file, is there anyway to bypass this?
    3) Undelete doesn't work.
    Any help here would be great.
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    instead of undelete you can first copy your cookies to a different folder, delete the temp folder, then copy the files back (or move if you like)
    windows likes to protect that folder.. you might be better off with something like "del c:\windows\tempor~1\*.* /s" I +think+ that works..
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
      2) use del /q will delete without confirmation (stands for quiet mode).
      3) There is no undelete since msdos .. Best way would be to copy the cookies out somewhere else first, delete all the cookies then copy them back.. You can do it in the batch file.
      MP3 Cavalier - http://www.mp3cavalier.com
      MP3 Grand Prix - http://www.mp3gp.com
        [DEL] will work to delete files
        [RMDIR] is used to delete directories
        You can't delete a directory that isn't empty.
        Try [RMDIR/?] for help on the switches for [RMDIR]
        Your process should probably be:
        [list=1][*]Copy your wanted cookies somewhere else[*][DEL *.* /q ] the contents of the cookie folder[*]Move the cookie files back to where they came from[/list=1]
        Batch files are fun!
        C!
        http://carpc.riposte.net
        I reserve all rights in connection to each post I author, without exception.
          /q doesn't seem to exist, I keep getting an error message.
          I've gone for the exporting then importing the cookies as the more sensible idea.
          I'm still having trouble acessing the Tempory Internet Items Folder, could and one confirm if I'm using the correct DOS name.
          Thanks for all the help so far.
            type [DEL/?], and this will give you all the switches for the [DEL] command.
            What version of Winders are you using?
            C!
              I think part of the problem is that the Temporary Internet Folder isn't really just A folder, even tho thats what windows shows it as. Its really a lot of folders. If you ever download something, say to your desktop, watch what happens when the download gets to 99%, it says copying file from temporary internet files/AQWRWEHGHER/download.exe.
              -Nick
              _____________________________
              www.mp3vw.com
                Re: Batch File
                Any help here would be great. [/B]
                1. Not sure how to help you here but make sure you can get to it with cd \windows\Tempor~1 from the command prompt to make sure you are using the right name.
                2. try something like
                ECHO Y | DEL [path] \*.*
                DELTREE /Y [path] \*.*
                Either of those might be better. The first one will put a Y into the buffer and run that on the next command so it will be like you trying Y to tell it to go ahead and delete whatever it is. I think you are running 95/98 and I am on windows 2k (as it seems like some other people are from the responces that you have gotten.
                3. yep so move the ones you want to keep ojut of the directory first like others have suggested.
                  Rob,
                  Im
                  Thinking of another way... I like what ShinkunoNamida said...
                  Just use TweakUI to clear everything, and have a simple batchfile copy the 2 files back from antother location
                  Greetz,
                  Raas
                  Raas - The Netherlands
                  ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
                  GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
                    Thanks everyone, it's all working nice and happilly now, and for reference I've attached the code I used.
                    Code:
                    cd C:\WINDOWS\TEMPOR~1
                    copy ROBHES~6.TXT c:\Windows
                    DELTREE /Y C:\WINDOWS\TEMPOR~1\*.*
                    DELTREE /Y C:\WINDOWS\TEMP\*.*
                    cd C:\WINDOWS
                    copy ROBHES~6.TXT c:\Windows\TEMPOR~1
                    del C:\WINDOWS\ROBHES~6.TXT
                      Code:
                      cd C:\WINDOWS
                      Why do you have it copy then delete ? I think windows 9X has a move command right ? just replace those 2 lines with something like
                      Code:
                      move c:\windows\robhes~6.txt c:\windows\tempor~1\
                      (test to make sure it works before using in the code)
                        I was (still am) using copy as it seemed a safer option when playing with the batch file, if something goes wrong I've got a spare copy in the other folder.
                        Now it's working I will change it over to move, like you mentioned, as it is better codeing practice.
                          This might be a stupid question, but WHY are you doing that?
                          Why not just set the caching size to something really small, like 20MB and then forget about it? That way you won't have to futz with everything.
                          Additionally under Internet Explorer there is an option (Tools / Internet Options / Advanced / Security : Empty Temporary Internet Files folder on exit) that can probably do what you want as well.
                          IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
                            From what I can tell, he wants to remove cookies as well as the temp files.
