question?
  • question?
    What would happen if you hooked a 12 volt fan (120x120 high amp sucking) to your battery instead of the PSU? Good Idea or Bad Idea?
    I finally find a theard that answered my question.
    ODYSSEY
    Originally posted by Tidder
    Digital-Car UK|
    (\__/)
    (")_(")
    hmm...i dont know
    But one time, we took a 80mm fan out of computer and stuck it out the window of my car going 80mph...it was spinning so fast it hurt our ears. I still wonder how fast that fan was going.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
      D batteries...
      I run 4 of my fans off of 8 D batteries = 12 V. I didnt want them running all the time and wanted to take my comp out easily (fans arent in or on comp), so using comp power was out of question. Rat Shack sells those battery packs for $1.99. Takes 4 D batteries and spits out 6v. Hook 2 of those together and you have 12v. Works well so far...
      I'm a ghost...email me if you have any questions on my old setup
      My way outdated website: http://www.poboytech.net
      FYI: I sold my 96 4Runner and bought a 1985
        Well I'm looking at lessing the load on my PSU. I'll just get a relay and a 3 amp fuse.
        ODYSSEY
        Digital-Car UK|
        (\__/)
        (")_(")
          I have my system fan connected directly to the 12V - the cpu fan not because it takes not much current -
          12VFAN on 12V should work ? or not`?
          i have my sytem hoocked up as the following
          Battery=> big big cable => PowerSplitter => Relais =>FAN&Inverter . So with a little switch i turn on and off my interver and system fan .
          Felix
          =>> Carpc Version2 -- Epia M 10K based<<=
          ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
          ::trying to build second low cost carpc::
          ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
            i have 2 12v fans for my ventilation system running off the car electrical system. no problem!
            99.9% complete.
            http://www.cardomain.com/ride/212327
              I think even if you have around 13-14 V while driving this would not dammage the fan. If you feel not good by connecting the fan directly take a cheap one so that it doesn't matter if it brakes.
              Ah yes forgot - Have some equipment at home which runs 24h/day and that needs a fan - This fan is connected to a 13,2V PSU - Until today - no problems
              Felix
                Running a fan at a slightly higher voltage (14vdc) shouldn't cause any problems, as people have said. If its a cheap fan, it could shorten its lifespan, but when you consider how simple of a mechanism and how cheap a fan is, whats to loose?
                -Nick
                _____________________________
                www.mp3vw.com
                  speaking of fans i found a stupid trick the other day while messing with one of those clear fans with the l.e.d's in it if you put it unplugged i front of another fan or something else that will spin the blades fast enough it generates enough power to power the l.e.d's like i said stupid trick but hey
                  WINNER!!!!
                  run-on sentance comp 2002!!
                    dynamo effect thats cool
                    My stupid idea of the day:
                    hey 12 fans on the cars roof 120km/h = great voltage *g*
                    Felix
