Math help needed!
  • Math help needed!
    I'm using this formula in some code i'm writing to get the percent of a number
    Percent = ((( X ) / 272) * 100)-10)
    This formula works. But i need a second formula that solves for x using the same constants... and adding a percent as a constant
    so lets say for example percent = 50.. how would i figure out what the heck x is lol.
    I knew i shouldnt have copied from the smart chick in math class
    Live mp3Car Facebook Chat
    I'm not exactly sure why you're offsetting the percentage by 10...
    Usually this is the formula:
    % = ( X / TotalItems) * 100
    If we solve for X, we get:
    X = (% * TotalItems) / 100
    So, your formula would be:
    X = (Percent + 10) * 272 / 100
    Is that what you're looking for?
    My Install : '08 Saturn Sky In-dash
      i'm offsetting because the slider is offset by 10. I'll try the formula and let you know the results
        Math homework?
        Just change the signs as you bring the numbers across the equals sign.
        Percent + 10 = ((x) / 272) * 100)
        Percent + 10 = 100x / 272
        272 * (Percent + 10) = 100x
        272/100 * (Percent + 10) = x
        2.72 * (Percent + 10) = x
        Ampie Case
        256 MB DDR2 PC5400
        Xenarc 700TSV - VGA Monitor
        Intel D945GCLF Motherboard
        M2-ATX-HV
        2005 Honda Civic
          Originally posted by Maheriano View Post
          Math homework?
          Nah not homework.. skin work..and it works! Thanks guys.. had been rattling my brain on that for some time.
            Yeah, Maheriano... That's what I said, (basically).
            The 272/100 will be compiled out.
            I enjoy math. Does that make me sick?
              A sadist maybe. I don't know, I do math all day long at work.
                Great minds think alike! I did it out for him though, so hopefully he'll understand how it works for next time.
                Ampie Case
                256 MB DDR2 PC5400
                M2-ATX-HV
                2005 Honda Civic
                  probably not but at least ill know where to search
                    Yeah. I write code all day at work. That is almost like doing math.
                      needless to say i still dont get it lol: i've got another slightly different formula i need help with. Same scenario only not dealing with percentages
                      X= ((160 * 2.5)-100) * 0.145
                      in the above function X = 43.5. I need to the solve an equation which gives me X but not "160"... so like this
                      43.5 = ((X * 2.5)-100) * 0.145
                      So how do i solve for X in that second equation
                        Are you reversing the math? The easiest way to think about it is to break it down and reverse each basic equation.
                        X = n * 2.5 reversed is n = X / 2.5 and keep going...
                        A = 160 * 2.5
                        B = A - 100
                        X = B * 0.145
                        reverse...
                        D = X / 0.145
                        E = D + 100
                        F = E / 2.5
                        So now F = 160
                        Now put it all back together
                        X = ( (43.5 / 0.145) + 100 ) / 2.5
                          well that took me awhile but now i get it. Thanks for the insight Curiosity!
                            I used to just draw a triangle and put the three numbers inside. 1 number at the top and 2 numbers in the bottom corners. So say you have A at the top, B in the left corner and C in the right corner. You can visually see how the equation changes:
                            A = B * C
                            B = A / C
                            C = A / B
                            I used that for years.
                            Ampie Case
                            256 MB DDR2 PC5400
                            M2-ATX-HV
                            2005 Honda Civic
                              In college i majored in Business Admin AND Info technology. If i ever go back i'll major in mathematics lol. I always get caught up with this kinda stuff in my programming.
