Who knows something about linear actuators?
  • Who knows something about linear actuators?
    Can linear actuators be made to 'step' forward and backward? A guy who was selling one on e-bay said that a standard linear actuator can only extend fully and retract fully, no in between movements. I was wondering if they can be made to do this, or if I need a special kind, and what that kind is
    I want an actuator that can be made to step forward say 2 inches, then maybe back 1 inch, then maybe forward 3 inches, back 2, etc do the hokey pokey and turn itself around, etc etc.
    Re: Who knows something about linear actuators?
    I can't help you with your question but here is a good website that might: http://www.selectproducts.com/frameindex.htm
    They have different size actuators and other things... Check it out.
    Armen
    http://www.digitalww.com
      you might have to look into linear stepper acuators. the ones i have seen online appear to be threaded rods that are surounded by a motor and gearing. the rod protrudes from both ends of the device. the motor turns the rod so that it extends or retracts form the body of the unit. they are supposedly very controllable. but with more precise control on the distance you are going to sacrifice speed of the unit. more precise positioning means slower retraction and extension.
      or you could use a basic stepper motor with a linage to transform the rotation to linear motion.... i dont know the requirements that you have, but there are options.
      and yes, as far as i know, linear actuators are only open or closed. i dont know the specifics of how they work, but thats what i have seen.
      ~mike
      Single Member of the "1000 Post and No MP3 Car" Club
      PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
      2000 Cavalier Z24 [###-------] Only 30% Done ... Still
        Assuming that the time taken to extend 1 inch is the same no matter how far it has already extended by then you could do it by timing the supply of power.
        I dont know if they have to extend fully before they can retract, but I would assume that they could, wouldnt you?
          Well...basically for my application, I need a linear actuator that is fast, but can be positioned somewhat accurately within say 1/4". It has to be able to repeat these positions several times, too. So I thought about setting up a timer circuit so that X seconds of power would move the actuator to position 1, etc. But this has its drawbacks in that it may take more or less time for it to move to a certain position, depending on temperature, available power to the device, and things like that. Maybe the best idea would be for me to buy a standard linear actuator that is fast, and then control the power using an LED and a phototransistor, when the actuator comes between them I would know that it has reached its destination and it should stop.
          Any other thoughts?
            Any other thoughts?
            I dont quite understand what youre trying to do. Linear actuators are basically the same as power window. It needs something to control the power feeding the motor. Are you trying to build a setup that's much like a motorized indash monitor, with the ability to extend fully then ables you to adjust the length 1 by 1? Almost all the linear actuator setups that Ive seen use pressure switch to control the actuator. A timer module is not always reliable due to the fact that sometimes it would take X seconds to completely extend the actuator, sometimes Y seconds depending on the battery voltage, temparture, and load.
            NEW complete and updated My project with 100+ pics on 7-4-03
            If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
              Yes, basically, I want to be able to make a circuit so that if I press button 1, it extends to 5 inches if i press button 2, it goes to being extended 2 inches, if i press button 3, it goes to being extended 12 inches, etc.
              What is a pressure switch?
                I would get it to trigger microswitch limit switches rather than anything optical.
                I get the feeling you want to be secret about your application, but it might help if you told us as there might be a better solution than an acutator.
                  Well here's a hint.
                  I'm going to attach the actuator to a cable. Then, accurately pulling that cable to different positions will do different things
                    Well here's a hint.
                    Weight jacking? For racing?
                    A pressure or limiter switch will probably be the most cost effect way of doing it. You will setup 3 reed or lever type switches at 5", 7" then at 12" each on its own button switch with a relay. When you hit the button switch, the relay will engage the Linear Actuator until it hits the corresponding lever switch witch will disable the actuator.
                    It will be a "poor man's" stepper actuator. I could probably sketch out a quick diagram to illustrate if it still isn't clear.
                    Chkdsk
                    Shuttle ST62K, 80Gb, MediaEngine, Irman, Wireless NIC, Win2K, Blah Blah Blah...
                      Well here's a hint.
                      Would that be to control Heat/AC and Fan speeds?.... sounds interesting
                      TruckinMP3
                      Read the FAQ!
                        Wouldn't this mean that the actuator is stopped at 5", 7", and 12" [in order] on its own? So, doesn't this prevent going from, say 5" to 12" (or 12" to 5") in one button push? If you had even more positions, this could get cumbersome.
                        BTW, why be so secretive?
                        No Carputer YET.
                        A car I'm designing...
                          You are correct - the lever switches would be "fixed distance" orientated rather than "steps". But you could press the 5" button and it would proceed to the 5" lever THEN press the 12" button and it would pass the 7" lever and proceed to the 12" lever.
                          I bet it's for weight jacking for a movable ballast, but it most racing (drag racing) it's illegal - am I correct?
                          Chkdsk
                            OK OK ILL TELL YOU ALL!
                            I'm going to attach it to the cable that attaches to my automatic transmission lever and bring back the days of the push-button transmissions. The transmission lever in the Malibu is really dumb so I'd like to replace it with just a piece of aluminum and illuminated buttons
                              OHHhhhh... I see... I thought it was something much more devious! Cool though.
                              The actuator you need will have to be fairly fast as you don't want to be waiting and waiting for it to go from Park to Drive. You will be able to do this with Relays and Levers for every single gear selection. The wiring will be complicated but not impossible because it will need to be smart enough to know which direction "Reverse" is from Park OR from Drive.
                              Chkdsk
