Cutting holes in sheet metal and other dangerous tales
  • Cutting holes in sheet metal and other dangerous tales
    I'm trying to mount some VGA, sound, and USB headers onto a single piece of sheet metal. Any thoughts on the best way to cut out those holes? The sound holes can be done simply with a drill, but the VGA and game port holes are going to be a *****.
    I would like this to be pretty clean, so let me hear your ideas on the best way to approach this.
    Don't Click
    You need a Dremel with a fine cut tungsten bit. That would do the trick
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
      you can get special punches that make exactly the right hole. i think there is a company called Greenlee or Greenleaf or something like that that makes them. They will be much cleaner than if you do it with a dremel but the punches will probably be $20 or more each.
        You can also try a PC backing template and cut a rectangle into the sheetmetal for the template and place the template into the rectangle.
        Many motherboards come with a custom backing template to accomidate special ports.
        SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
        GPSing - Digital Speedo
        Relocating headunit and extending faceplate
        Button app to Alt-Tab between two programs
          brrman - That's most likely how I'll do it. I still have the original metal brackets that they were connected to so I can just use them as templates.
          StationRocket - That's a good idea about the punch, Station, but waaay too expensive. http://www.mouser.com/catalog/618/1258.pdf Maybe there are cheap alternatives out there.
          LESLIEx317537 - If I could cut a clean rectangle, then I could just cut a clean hole for the VGA and game ports.
          Don't Click
            I used a drill to start all the holes, tin snips for the larger areas, then a dremel as brrrman suggested for the edges for my aluminum faceplate.
            To do the square hole for the USB port, I just drilled a starter hole, then taped the old steel mounting bracket for the USB port in the proper place to the aluminum face plate without the wire in it and dremeled the hole out until the edges were perfectly even.
            StreetDeck.com Developer (I am Chuck)
            Get StreetDeck at http://www.streetdeck.com
            The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
              Wow, nice work on the hard drive mount. That's the most elaborate one I've seen yet.
              Don't Click
                try this at compusa
                http://www.compusa.com/products/prod...srch1&ref=goog
                  Holy crap. Have you used it before? Do you know how well it works?
                  Don't Click
                    i have one of those
                    it's called a nibbler. it's what i used to make the holes in my case for the power entry and the other stuff that wasn't included in the plate that came with my epia motherboard.
                    Just like using a dremel it will do alright if you work slow and have good hands.
                    i'd try out your skills on a spare first
                      All that is... is sheet metal scissors. You can get them at any hardware store. That wont help you cut clean holes.
                      VIA Epia II
                      256MB 266DDR Ram
                      90GB Wester Digital
                      Bluetooth/Deluo GPS
                      Lilliput 7" Touchscreen
                      Mazda 6 Carputter > Click Me!
                        Oh, nevermind. I was hoping it was specially designed for cutting out holes like what I was talking about.
                        I have a nibbler and sheet metal scissors, but they're both too big for this type of application.
                        Don't Click
                          Tin snips are just nice if you have stuff that's hard to cut. I used it to fit some 6x9 speakers in the back, but its really ugly and I need to use a dremel.
                          Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
                          Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
                          Head units are for cheaters!
                          sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
                            Just go to your local college and ask if you can use their laser router. just design what even you need to cut out in a monocrome coral draw file and the machine with cut it out for you. I had a friend that had a laser ingraving router, you can use those too, but you just have to make sure that you have the engraver "print" over at least 20-30 times.
                            Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
                            Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
                            S2000 Carputer
