Calculate LED Watts
  • Calculate LED Watts
    I've got these SuperFlux LEDs from Lumileds. They have a forward voltage of 2.5V so I am stringing 4 of them in series. How do I calculate the total current and power?
    +12V ----|>------|>-----|>------|>-----GND
    Max current: 70ma
    Power dissipation: 221mW
    Forward voltage: 2.5V
    221 mW / 2.5V = 88.4 mA
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
      But he has 4. So 353.6 mA. I think...
      My Carputer! (More Car Pics at the end)
      2 Kicker Comp 10"
      Epia M-9000, 256 MB DDR, 120 Gig HD
      Lilliput 7" VGA Touchscreen
      Check it out?!
        Thanks. A few more questions
        a) Assuming a 10V power supply, wouldn't it be 0.175W per LED ( P = IV = 70mA * 2.5V)?
        d) When analyzing circuits can I treat LEDs as a resistor?
        b) Do LEDs have a series resistor in them?
        c) In this case equal to 35 ohm (R = V/I = 2.5V/0.07A)?
        d) These have a min and max flux rating. Is a higher flux achieved by running a higher forward voltage?
        Thanks again!
          Max current: 70ma
          For practical purposes, a good, working LED has no resistance, it does however, produce a voltage drop.
          The circuit as drawn is only going to blow LEDs. Given the whole V = I * R thing, and that LEDs have almost no R, to calculate the current flowing in the LEDs is I = V / R. As R gets really small, I gets really big. Since the max. current for these things is small (70mA) you'll fry them before you see them light up.
          To fix this you need a resistor.
          12V is the source, and each LED drops 2.5V so 12 - 2.5 -2.5 -2.5 -2.5 = 2V. 2V is the remaining pressure you have to drop, and you want to draw less than 70mA doing it. Again V = I * R. This time you want R, so R = V / I = 2 / 0.070 = 28 Ohms. You wont find a 28 Ohm resistor, so get the next biggest size, probably a 30.
          Power is calculated for this circuit with P = V * I.
          A 28 Ohm resister would give you 70mA through each LED, but your using a different one, so you need to calculate the actual current. V = I * R (seeing a pattern yet?) I = V / R = 2/30 = 0.066 = 66mA.
          Power for each LED is V*I = 2.5 * 0.066 = 0.165W = 165mW. And there are four of them: 4 * 165mW = 660mW. Don't forget the energy being dissapated by the resister at 2V * 66mA = 132mW. So the whole thing is eating up 660 + 132 = 792mW.
            Dammit Sparc, good post. I wanted to sound all nerdy, but it looks like you beat me to it... =b
            "Is Wayne Brady gonna have to choke a b@$#*??!!"
