Anyone into modding the motor?
  • Anyone into modding the motor?
    Wondering how many gear heads we have here?
    It's my first passion...
    current project is a 1999 Dakota R/T P/U. Mods are as follows:
    Paxton Novi2000
    MSD BTM
    MSD 6AL
    PPH headers
    gutted cat
    Spintech with turn downs
    Mopar PCM
    Hotchkis
    2 x 52 x 55mm F&B Throttle Body
    FMS 24# injectors
    2bbl M1
    viper fan
    reworked factory fuel rails
    APS 2800 stall
    Cal-tracs
    50# aux injectors (paxton only provides 30#)
    Dyno:
    345 rwhp, 360 ft-lbs on a Mustang dyno
    Times:
    [email protected]; 2.0 60'
    That time was on a damp track with a stall that had not fully broken in....also, it was only the second run on the current set-up....with any luck....might hit a HIGH 12.....like a 12.999999999
    hehehe
    wondering if anyone else has any projects that involve going faster too
    Jan Bennett
    Hmm, only chipped my volvo to 198 HP - it's a diesel
    But there are some racers on the forum here!
    List of front-ends/usefull apps
    XTroniC | XTroniC Direct
      I drive a saturn. I can't race
      On a saturn racing (tee hee hee) forum, there are guys who have spent $15,000 on turbos, nitrous, suspension upgrades, etc. to get a 15 second car. Thats in addition to the price of the car. If I'm gonna spend that kind of money, I think I'll just buy a used mustang GT.
      Debt as of 1/1/05: $34,354.48
      Debt as of July 4, 2007: $0.00 explanation
      I'M DEBT FREE!!
      I'm now a reasonably successful gunblogger.
        hey now - I have a very close friend of mine who use to race a Saturn....SC2??? in auto-x years ago. This was before there was much that you could buy out there for the Saturns. He made everything. Exhaust, intake, etc. His class was "Show Room Stock" meaning you couldn't change much on the car from the way it came from the dealer. It was more about the driver....and MAN is he a good driver! 9th at nationals in his class....I'll see if I can find something online about him.....but that was YEARS ago....
        some people say the same thing about just about any car out there....but hey, if you enjoy it that's all that matters, right?
        Jan Bennett
          Im a gearhead myself.
          I just transplanted a Jspec 2.0L V6 in my other MX-3.
          I bought it as my project car, incidently, its where my carPC is going.
          2011 Nissan Frontier SL
          AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
          OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
            sweet!!!
            Jan Bennett
              Im gonna pull it back out. Im using mostly parts from an american 2.5L v6. Since the motor I have is high compression, im putting in a 2,5L with lower compression so I can put on my turbo and get more boost.
                lol Barry i was gonna ask what the blue thing was you added to the KL. upon second look.. its just a flashlight
                Live mp3Car Facebook Chat
                  How much HP does the flashlight add and are they available for volvo?
                    lol 5Volts DC
                    thats not a KL.. thats a KFZE.
                      Z06 - 3.73 gear gears with hardened outputshaft, short shifter, throttle body coolant bypass, blackwing intake, dyno tune, 379.9whp
                      Eclipse GSX - you ready ? :
                      1999 Eclipse GSX
                      Exhaust
                      3" Custom Exhaust with magnaflow 3" in dual 2.5" out
                      3" downpipe
                      TIAL 46mm wastegate
                      VP Stainless 02 housing
                      Evo 3 exhaust manifold
                      Intake
                      BR 20g turbo
                      dejon 3" intake pipe
                      Apexi air intake with heat shield
                      HKS SSQV bov
                      Sparco 2-272 intercooler with custom 2.5" polished piping
                      Engine
                      Stock block, rods and pistons
                      BJ Cylinderhead street port head with Crower double springs +retainers
                      Removed balance shafts -new oil pump
                      HKS 264i, 272e cams
                      Fluidine radiator
                      SPAL simline dual 10" fans
                      Polyurathane motor mounts
                      Fuel
                      FIC 650, 750 and stock 450 injectors (trying to figure out fuel issue!)
                      Supra TT fuel pump, stock wired
                      -6an braided steel lines from tank to filter
                      Aeromotive fuel filter
                      Paxton adjustable fuel pressure regulator
                      AEM fuel rail
                      Electronics
                      SPA dual boost/egt gauge
                      SPA dual fuel pressure/oil pressure gauge
                      Apexi AVCR boost controller
                      DSMLink v2 ECU upgrade
                      Techedge wideband 02 sensor kit
                      Apexi turbo timer
                      Palm pilot to program fuel/timing/logging etc..
                      Kenwood headunit, rockford amps, JL sub
                      Exterior
                      TSW Avus R 17" wheels
                      Sumitomo HTR 235x45's
                      Suspension
                      RM anti-sway bars, front and rear
                      Transmission
                      ACT 2600 clutch
                      NEO RHD Transmission fluid
                      B&M Short shifter
                      Spearco shift knob
                      Brass shifter bushings
                      Symborski shift plate kit
                      Goodridge braided steel brake lines
                      Brakes
                      AEM big 12.5" rotors
                      Porterfield rs4s pads front and rear
                      Braided steel brake lines
                      it will get dyno'd once I fix the AC and a small intake leak, then its going on ebay to pay for the z06 supercharger
                      The bike is a Monster 800 dark, did an intake and the race pipes, probaby makes 80hp but it only weighs about 400Lb's...
                      Cheers,
                      Grant
                      '03 Corvette Z06 - car pc soon
                      '99 Eclipse GSX
                      '03 Ducati Monster
                        Originally posted by Custommx3
                        lol 5Volts DC
                        Ah yes. My mx3 knowledge is a bit rusty since i seldom visit the board anymore.
                        Anyways, I currently have a half turboed 01 nissan alty thats bein returned to stock so i can trade it in on a mazda 6 hatchback. Plan on transferring whatever turbo parts i can over to work with the new car.
                          Sweet!!!
                          Again, I'm glad to see another Duc owner on here.....I have my 750 Sport and my Boyfriend has a 750 Monster....we're both looking to upgrade..MV Agusta for me (yEAH!!!! right!!! like I can afford that!!!) and a S4r for Monte.....maybe once we graduate....heh
                          Jan Bennett
                            Both of my current cars are power adder cars.
                            My daily driver is a '88 Escort with a IHI turbo, Accel DFI fuel injection with wideband o2, and a Spec stage 3 clutch. It has a late model ported head and tubular intake and the 2.5" exhaust should be done early January. Just passed emmisions, took a few trips, but the guys were totally stumped how I could return 5 minutes later and have completely different results. I love it, the car is totally stock appearing and will leave a mildly modified 'stang on the highway. Traction is somewhat of an issue light to light
                            My '91 Mustang has a *true* Saleen body set with the year specific wing, and as of tonight an Aluminum headed 351w with a 9# Powerdyne supercharger. Has a Canton pan, blower grind cam, and roller rockers. The transmission is a AOD automatic with a 3200 stall non lockup convertor and a lentec valve body with pushbutton O/D. 3.73 gears but replacing with 3.27 soon as the drag radial class will be very traction limited. The engine made 425hp and 450ft/pds of torque on pump gas in the prior car that I pulled it out of and ran a best of 11.40 with no traction and a stock auto trans on drag radial.We are changing that car to a big block over the winter.
                            ----jeff
                            2005 Ford Focus ST
                              Does fixing all of the various places that the motor leaks qualify as modding the motor?
                              otherwise I've got a diesel swap/tranny swap in the background, probably never happen.
