Manual Shifter for driving games
  • Manual Shifter for driving games
    Are there any off-the-shelf shifters (and 3-pedal setups) for current driving games? Looking for standard as opposed to sequential shift. Googled a bit and found some stuff by Act Labs (http://www.actlab.com/Products/race1.htm), but it looks like its been discontinued and game support is questionable. Any known alternatives?
    1984 Fiero EV conversion:
    180VDC Saft NiMH 106Ah batteries, Solectria AC42 AC Induction motor and UMOC445 Motor Controller
    A few pics at http://www.paulminear.com/images/pic...EV_Conversion/
    Logitech's Momo Wheel has the shifter, but not the 3-pedal setup. I'm sure you can map the clutch to one of the steering-wheel buttons, but I'm sure that's not what you're looking for.
    If you want a true 3-pedal setup, you're going high-end.
    Here's a couple links:
    ECCI: http://www.ecci6000.com/6000_productportal.htm
    Frex: http://www.frex.com/gp/
    How about the Wiki?
      I've always thought it would be cool to have something like that.
      My Install Thread
      digitaljetta.com
      MKIV VW Jetta
      How do I get sound to my car?
        Interesting...
        So, how does it work? It won't let you change gear unless the clutch pedal is pressed? Anyoine used this before?
        Renault Megane...the OEM look
          Hmm,
          The only game I have seen that uses clutch, munual stick and even the ignition key is an arcade game called harddrivin made by atari.
          Probably the most accurate simulator made.
          What PC or console game would support that sort of hardware?
            Rush 2050 or something is an arcade game with a clutch. but as far as having a clutch in a game goes, good luck. No games are programmed for them.
            Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
            Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
            Head units are for cheaters!
            sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
              Originally posted by Chris31
              Hmm,
              I LOVED that game. Playing it on the console (Sega) wasn't half as fun. I wonder if there are still arcade games with clutch and gear box?
              My Install Thread
              digitaljetta.com
              MKIV VW Jetta
                the act labs setup is so far the only one ive been able to find. but as you said, its discontinued. it can still be found, just a PITA is all
                Your everyday carpc geek and tech guru at your service. *bow*
                  I was learning how to drive then, I must say it did helped me alot to coordinates my feets. Hehe, I remember stalling the engine and restart it by rolling the car on the hill while engaging on 2nd gear, kinda cool.
                  I think some of the best arcade controls are the one found in "Daytona", "Sega Rally", "Virtua driving" and some later ones, proper pedals and force feedback love to have one at home Havent played for ages, Im sure theres better ones now.
                  Shame still no clutch
                    The higher-end racing sims support advanced controls like that.
                    NR2003 by Papyrus (RIP) supported all sorts of hardware. It's the NASCAR sim that the actual drivers use for training. EA's NASCAR SimRacing should support these as well.
                    The PC Rally games (Colin McRae) use advanced controls as well. I'm also pretty certain there is an F1 sim and a forthcoming sports car race sim that will have advanced wheel support.
                    How about the Wiki?
                      the act labs shifter also has a utility that allows it to be used with racing/driving games that dont support it iirc.
                        The only good answer is that you should make a utility that connects to your OBD-II interface and uses it to monitor the pedals, gear shift, and steering wheel of your actual car. That way, you park, turn off the engine (important) and then use your car controls to control the car in the video game on your carputer.
                        Geez, do I have to think of EVERYTHING here?
                        Chrysler 300 - Fabricating
                        http://hallert.net/
                          I have seen a setup like that, in an arcade several years ago. They had a JDM Miatia hooked up to Ridge Racer, projecting on 3 8'x8' screens. Pretty damn cool.
                          As for the wheel, good luck. I think there are a lot of games, pc especially that might support it, but there just isn't the demand for it for hardware manufacturers to make a wheel like that. You could always make your own.
                          I am pretty sure that RUSH gives you a little boost if you use the clutch, but it doesn't penalize you if you don't. The only arcade game I can think of that you have to use the clutch in is the ferarri simulator game.
                          BTW the momo wheel has the sequential shifter.
                          |V1 Virtual Display|
                          Hard work often pays off over time, laziness always pays off right now.
                            One of those links I posted will convert your wheel to use genuine racing steering wheels by Sparco or Momo (maybe others?) with a H-shifter. You can also add the 3rd pedal if you desire.
                            It ain't cheap, though.
                            How about the Wiki?
                              http://www.simbin.com/games/
                              this game has a clutch button too
