Bumper sticker kits?
  • Bumper sticker kits?
    I went to Staple's and they didn't have anything that looked like it would work. And I googled, but I really don't know what I'm looking for, or if any of the kits I found are any good.
    Has anybody done these themselves, and what kits did you use? Also, I would like to make those stickers that go on the inside of the windows, but aren't really adhesive. You know which ones I'm talking about?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    If you just want a couple of stickers, use cafepress. $3 per bumpersticker is spendy, but cheaper then buying the infrastructure if you're only doing a couple.
    Chrysler 300 - Fabricating
    http://hallert.net/
      That will work, and $3 isn't bad. I was expecting more for custom bumper stickers.
      Now, if I could find the ones that go on the inside of the windows.
      2000 Subaru OBS
      Dell P3 @ 900 Mhz
      80GB External HD
        I can do custom vinyl stickers for you... but anything I make will be sticky...
        Your talking about window clings... that stick from static charge basically... I can't cut those out..
        Those need printed which I can't do....
        But anything else... gimme a hollar...
        CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
        Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
        Display: Lilliput 7" TouchScreen
        CarPuter Install
          they sell something like that a walmart
          its made by hammermill its not as good as vinyl but it sticks to glass
          and you can print on it, its called clear window decals - I had got them
          to cut up for PDA screen protectors and found out there no good for that,
          there like a transparency with a static cling side
          They also sell a paper with a sticky back that can be printed on
            I had some of those hammermill things from walmart, I had printed tux and put it in my window, last week when it started getting warm, the ink melted off and im still trying to get it off of the window...so be careful with those
            I had a perfect quote to go here,
            but hell only knows what I did with it....
              Ouch.. permanent tux on ur window...
              Just use real vinyl stickers.. u can use some heat and peel them right off
              or use razor blade on glass.. much nicer and easier....
              What do you want your stickers to say?? I'll hook you up cheap!
              Gotta keep it real for the fellow PA'r's
              CarPuter Install
